How to move Aimeos (Typo3-Dist) from one server to another?
franzrudolf
Hi again,
I've been working on it for hours but I just don't understanding the logic of product exporting/importing...
I've built an Aimeos-shop on my server. Now I would like to move the entire TYPO3-/Aimeos-System to another Server. First of all I tried the usual way: Installing the TYPO3-Source on the new server, overwriting the fileadmin-, typo3conf and uploads-directories by the respective backups and finally importing the DB-data. But instead of the products I have created (and which I can see in the DB) only the demo-products are shown. Therefore, I guess, I have to use the scheduler-task "Produktexport" (in the old system) to export the catalog as a file - am I right?
But I have no idea at all, where this file will be stored, or how I can configure the task. Everything I have found in the docu is about import but nothing about export. Or am I simply too stupid to understand?
I would be very grateful for any help
Best regards
Best regards
franzrudolf
Re: How to move Aimeos (Typo3-Dist) from one server to anoth
Now I tried the following TSconfiguration in the task:
plugin.tx_aimeos {
settings {
controller.jobs.product.export.location =.../fileadmin/aimeos_exports/exports/
(I created the the aimeos_exports-directory in advance)
Since that I get the following error-message:
Die Ausführung von Task "Aimeos Shop Planer (aimeos)" ist fehlgeschlagen mit folgender Meldung: Unable to create directory "http://.../fileadmin/aimeos_exports/exports/"
plugin.tx_aimeos {
settings {
If you want to move your entire installation, your first attempt is correct. Copy all files and directories (exclude ./typo3temp/) and make a full dump of your database which you can import as SQL into your remote database. Adapt your database settings in the ./typo3conf/LocalConfiguration.php. Afterwards, you may clear the TYPO3 caches but then everything should be as in your local environment.
franzrudolf
Finally, I've made it - by the usual way as described!
Maybe this might be a tipp for others having the same problem:
I guess the Problem was that I first added the command "drop table" to my db-dump. Since I imported a new dump without "drop table" everything works as in the original system (I have only very little sql-knowledge but this was the only difference to my former attempts).
franzrudolf
Finally, I am completely confused...
As I wrote I moved from the old to a new server - and it did work. But now it doesn't anymore...
I repeated exery single step as described above. But after all I got an error in the admin-interface (compare file).
As I wrote I have only very little knowledge of sql but the (in the error-text yellow marked) db usr_p223362_9 is not the db I use - but one I have used before (on the new server)!
- aimeos-error.jpg (129.45 KiB) Viewed 17004 times
franzrudolf
I just realized that my last post is not quite understandable. The first move to the new server did word and still does.
The error came with another move of the installation (but everything identical to the first one).
franzrudolf
After I changed the db another time it works again... Even if I have not a clue why.
I am really sorry for making such a mess in the forum but to me this whole caching-system (which, I guess, was/is sowhow the problem) ist absolutely confusing.
