Configuration Problem Address.billing and countries
Hi there,
I got the following code snippet
First Problem, in the frontend are more fields shown then the specified fields in mandatory configuration e.g. telephone and language. I just want to show these 8 specified fields in the frontend.
Second Problem, in my countries dropdown are much more countries (all countries). The only thing that works is, that Germany is on the first place in the dropdown, so the configuration kind of works.
How can I get rid of the other countries?
Thank you in advance
[pb]
plugin.tx_aimeos.settings.client.html.checkout.standard.address.billing.mandatory {
0 = order.base.address.salutation
1 = order.base.address.firstname
2 = order.base.address.lastname
3 = order.base.address.address1
4 = order.base.address.postal
5 = order.base.address.city
6 = order.base.address.countryid
7 = order.base.address.email
plugin.tx_aimeos.settings.client.html.checkout.standard.address.billing.optional {
plugin.tx_aimeos.settings.client.html.checkout.standard.address.countries {
0 = DE
# Andorra
1 = AE
[pb]
Re: Configuration Problem Address.billing and countries
There are also optional fields configured:
https://aimeos.org/docs/Configuration/C ... g/optional
You can configure the country list as well:
https://aimeos.org/docs/TYPO3/Configure ... ons_states
Hey there,
thank you for the response.
I think everything is configured in the code example above, just scroll down. There is a config for optional (empty) and a configuration for the countries with Germany and Andorra.
Greetings [pb]
Greetings [pb]
The configuration was merged with the existing one which is not the desired result. This has been changed in dev-master now. Can you give it a try?
Thank you very much.
I'll give it a try.
[pb]
I'll give it a try.
[pb]
it seems to work partly. Countries are working like a charm. At the moment my configuration looks like this:
I would expect to see the following fields, marked as mandatory
salutation
firstname
lastname
address1
postal
city
countryid
and email as optional
But, as you can see in the Screenshot, there are more fields.
E.g language and I want to get rid of the disabled (grey) fields
Thanks in advance
[pb]
0 = order.base.address.email
0 = DE
1 = GB
salutation
firstname
lastname
address1
postal
city
countryid
Thanks in advance
[pb]
- Bildschirmfoto 2016-08-04 um 09.58.24.png (63.41 KiB) Viewed 16059 times
I've found the "hidden" configuration option but it doesn't do anything
Funny fact: The fields telefax and website aren't disabled anymore.
plugin.tx_aimeos.settings.client.html.checkout.standard.address.billing.hidden {
0 = order.base.address.telefax
1 = order.base.address.website
"mandatory", "optional" and "hidden" are CSS classes that are applied the the fields and "mandatory" fields are first enforced in the frontend via JQuery and later in the backend. Can you have a look if your CSS does still hide elements with the "hidden" class?
Now we found it. The default style for form-item is and only the optional and mandatory classes have
Thanks for helping.
display: noneCode: Select all
display: list-itemCode: Select all
.checkout-standard-address .form-list .form-item {
display: none;
.checkout-standard-address .form-list .mandatory, .checkout-standard-address .form-list .optional {
display: list-item;
