Bootstrap_package backendLayouts in fileadmin
Tony
Post by Tony » 27 Sep 2016, 15:15
I want to customize 2 bootstrap BackendLayouts away from the default location.
With other typo3 bootstrap_package projects/ installations I place the backendlayout files in fileadmin and it works without any difficultly.
I want this file: /typo3conf/ext/bootstrap_package/Configuration/PageTS/Mod/WebLayout/BackendLayouts/special_start.txt
to be located here:
fileadmin/bootstrap_package/Configuration/PageTS/Mod/WebLayout/BackendLayouts/special_start.txt
Normally this works - adding this to my homepage/root page TS script: <INCLUDE_TYPOSCRIPT: source="fileadmin/bootstrap_package/Configuration/PageTS/Mod/WebLayout/BackendLayouts" extensions="txt">
On this Aimeos installation it does not work. How can I place a custom backend layout in fileadmin and get it to load?
Many thanks,
Regards,
Tony
Tony
Re: Bootstrap_package backendLayouts in fileadmin
Post by Tony » 28 Sep 2016, 19:03
here's my answer should anyone else have the difficulties I had:
Put this in the root TS setup:
<INCLUDE_TYPOSCRIPT: source="DIR:fileadmin/bootstrap_package/Configuration/PageTS/Mod/WebLayout/BackendLayouts" extensions="txt">
The above script also bypasses this file:
/typo3conf/ext/bootstrap_package/Configuration/PageTS/Mod/web_layout.txt
This can also be set:
general.disablePageTsBackendLayouts =1
this is found in the extensions > bootstrap_package >configuation
Tony
P.S. How do you close a thread on this forum? :?:
Post by aimeos » 29 Sep 2016, 07:53
Topics are not closed. Everybody can add new posts later
