CSV Import
derJu
CSV Import
Post by derJu » 01 Dec 2016, 13:39
how can I integrate the newly created fields into my inport?
best regards
Screen Shot 2016-12-01 at 14.36.20.png (109.28 KiB) Viewed 5904 times
Re: CSV Import
Post by aimeos » 02 Dec 2016, 11:07
Can you please add more details what you would like to achieve? It's not clear from your screenshot and description.
derJu
Re: CSV Import
Post by derJu » 02 Dec 2016, 15:45
Sorry,
thats my code, i try to import my own types inside see printscreen of my first contribution:
controller.common.product.import.csv.separator = ,
            container.type = Directory
            location =  /var/www/vhosts/demo.de/httpdocs/typo3temp/aimeos/
            mapping {
               item {
                  0 = product.code
                  1= product.label
                  2 = product.type
                  3 = product.status
               text {
                  4 = text.languageid
                  5 = text.type
                  6 = text.content
                  7 = product.text.languageid
                 8 = product.text.type
                 9 = product.text.content
              catalog {
                 10 = catalog.code
Re: CSV Import
Post by aimeos » 05 Dec 2016, 14:12
If you want to use more text types, you have to add them in the admin interface first and than you can use the codes in your CSV file. Is that what you've meant?
