Feteching data from repository
NewUser
Post by NewUser » 24 Mar 2017, 13:10
I would need to fetch certain details from mshop_catalog and mshop_product tables. Can I get the repository names of these for object injection??
Re: Feteching data from repository
Post by aimeos » 24 Mar 2017, 13:37
Aimeos doesn't use ExtBase for managing and retrieving data. That wouldn't be portable and too slow.
Instead, you should use the Aimeos managers to get the data you need:
https://aimeos.org/docs/Developers/Libr ... ging_items
To get the necessary Aimeos context in TYPO3, use
$config = \Aimeos\Aimeos\Base::getConfig();
$context = \Aimeos\Aimeos\Base::getContext($config);
or if you extend from "Aimeos\Aimeos\Controller\AbstractController":
$this->getContext();
NewUser
Post by NewUser » 24 Mar 2017, 13:57
Thank you. It was helpful.
