Error Template text-salutation-header-default.php not availa
i am getting this error when trying to run the cronjob for the emails.
i run the cronjobs from the scheduler:
any idea why it cannot find the template file?
it certainly is there
`ff-laravel/ext/ai-client-html/client/html/templates/email/common/text-salutation-header-default.php` exists
my shop.php
just another debug:
`ff-laravel/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php`
$this->path is:
hope it helps
so the folder aimeos is trying to access is this: (debug from resolve() function of the View)
`/home/myuser/IdeaProjects/myapp/ff-laravel/ext/ai-controller-jobs/controller/jobs/templates/email/payment/5/text-salutation-header-default.php`
this is obviously wrong. Even though i call it from a controller, it should look in a different folder.... someone can shed some light into this?
#16 {main} Error while trying to send payment e-mail for order ID "9" and status "6": Template "email/common/text-salutation-header-default.php" not available
Trace: #0 /var/www/html/myapp/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php(219): Aimeos\MW\View\Standard->resolve(Array)
#1 /var/www/html/myapp/ext/ai-client-html/client/html/src/Client/Html/Email/Payment/Text/Salutation/Standard.php(167): Aimeos\MW\View\Standard->render(Array)
#2 /var/www/html/myapp/ext/ai-client-html/client/html/src/Client/Html/Email/Payment/Text/Standard.php(187): Aimeos\Client\Html\Email\Payment\Text\Salutation\Standard->getHeader('', Array, NULL)
#3 /var/www/html/myapp/ext/ai-client-html/client/html/src/Client/Html/Email/Payment/Standard.php(152): Aimeos\Client\Html\Email\Payment\Text\Standard->getHeader('', Array, NULL)
#4 /var/www/html/myapp/ext/ai-client-html/controller/jobs/src/Controller/Jobs/Order/Email/Payment/Standard.php(159): Aimeos\Client\Html\Email\Payment\Standard->getHeader()
#5 /var/www/html/myapp/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Command/JobsCommand.php(60): Aimeos\Controller\Jobs\Order\Email\Payment\Standard->run()
#6 [internal function]: Aimeos\Shop\Command\JobsCommand->fire()
#7 /var/www/html/myapp/vendor/laravel/framework/src/Illuminate/Container/Container.php(507): call_user_func_array(Array, Array)
#8 /var/www/html/myapp/vendor/laravel/framework/src/Illuminate/Console/Command.php(150): Illuminate\Container\Container->call(Array)
#9 /var/www/html/myapp/vendor/symfony/console/Command/Command.php(256): Illuminate\Console\Command->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#10 /var/www/html/myapp/vendor/laravel/framework/src/Illuminate/Console/Command.php(136): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#11 /var/www/html/myapp/vendor/symfony/console/Application.php(841): Illuminate\Console\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#12 /var/www/html/myapp/vendor/symfony/console/Application.php(189): Symfony\Component\Console\Application->doRunCommand(Object(Aimeos\Shop\Command\JobsCommand), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#13 /var/www/html/myapp/vendor/symfony/console/Application.php(120): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#14 /var/www/html/myapp/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(107): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#15 /var/www/html/myapp/artisan(35): Illuminate\Foundation\Console\Kernel->handle(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
<?php
namespace Ffix\Console;
use Illuminate\Console\Scheduling\Schedule;
use Illuminate\Foundation\Console\Kernel as ConsoleKernel;
class Kernel extends ConsoleKernel
* The Artisan commands provided by your application.
* @var array
protected $commands = [
Commands\Inspire::class,
* Define the application's command schedule.
* @param \Illuminate\Console\Scheduling\Schedule $schedule
* @return void
protected function schedule(Schedule $schedule)
$minuteCronJobLog = base_path() . '/storage/logs/cronjob_minute.log';
$hourCronJobLog = base_path() . '/storage/logs/cronjob_hour.log';
$dayCronJobLog = base_path() . '/storage/logs/cronjob_day.log';
$outPutDateTimeFn = function () {
$date = date('Y-m-d H:i:s');
echo $date . ': ';
$schedule->command('aimeos:jobs "order/email/delivery order/email/payment order/service/delivery"')
->everyMinute()
->before($outPutDateTimeFn)
->appendOutputTo($minuteCronJobLog);
$schedule->command('aimeos:jobs "customer/email/watch order/cleanup/unfinished order/service/async order/service/payment"')
->hourly()
->appendOutputTo($hourCronJobLog);
$schedule->command('aimeos:jobs "admin/cache admin/log order/cleanup/unpaid product/bought index/rebuild index/optimize"')
->daily()
->appendOutputTo($dayCronJobLog);
my shop.php
'client' => array(
'html' => array(
'common' => array(
'content' => array(
'baseurl' => 'http://ffix.local/',
'template' => array(
'baseurl' => public_path('packages/aimeos/shop/elegance'),
'email' => array(
'from-email' => 'hithere+testaimeos@gmail.com',
'from-name' => 'Test Aimeos',
just another debug:
$this->path is:
array (
'/var/www/html/fixturefix/ext/ai-controller-jobs' =>
array (
0 => 'controller/jobs/templates',
Re: Error Template text-salutation-header-default.php not av
Which Aimeos version are you using? Do you use the latest stable one (~2016.07)?
exactly 2016.07.2
solution: downgrade to 2016.4.03
i must say, I am not very impressed.
after downgrading and seeing it work, i upgraded again
no, stops working again.
there was another error even that i didnt even dared to mention.
It said something like
'service provider has no function process'
that is, in 2016.07.2
in 2014.04.3 it seems to work
There was a mismatch between the new outsourcedt ai-client-html extension and the Laravel integration. We've fixed that and have released a new minor version of the HTML client.jossnaz wrote:after downgrading and seeing it work, i upgraded again
Aimeos is a community project and lives from its contributors. Like Laravel, we release often to get new versions early to the users. This may lead to bugs that are quickly fixed and compared to Laravel, the number of bugfix releases is quite small. If you need a rock solid version, you should use the Aimeos LTS version.jossnaz wrote:i must say, I am not very impressed.
Cheers
Andi
Can you post more information about the error, maybe a stack trace?jossnaz wrote:'service provider has no function process'
i thought stable somehow means that someone at least tested it once. For people wondering about LTS... it would be good if you leave a note about it on the installation page. I didn't know there exists LTS for aimeosaimeos wrote: If you need a rock solid version, you should use the Aimeos LTS version.
Cheers
Andi
https://aimeos.org/project/roadmap/
so we can expect LTS at 2016.09?
another recommendation:
Change the name of the forum link to "forum" and not "help"
go to https://www.amazon.com/ and click on help. That is what one expects from a help link. I never knew the forum existed until i found a post for an error i had. And i was like "oh there is a forum, so i don't have to post issues to github..."
You ran into a problem that only surfaces when using the demo data. In real projects nobody noticed that up to now because this combination isn't used there.jossnaz wrote: i thought stable somehow means that someone at least tested it once. For people wondering about LTS... it would be good if you leave a note about it on the installation page. I didn't know there exists LTS for aimeos
We have unit tests for 90% of the code but sadly, that doesn't say that it's bug free. Some areas are hard to test automatically because there are too much dependencies like in this case (create an order in the frontend, run the Laravel jobs on the console). Our tests always include frontend and backend but not always the jobs. This is something where we may need to get better.
We will add a hint about this. The current LTS version is Aimeos 1.2 for Laravel from October last year.
The next LTS release will be 2016.10 in the first half of October. The new big features has been implemented in the first half of this year so we are mainly polishing the current stable version to get it as bug free as possible and update the documentation.jossnaz wrote:so we can expect LTS at 2016.09?
OK, that's a good hint. Thanks!jossnaz wrote:Change the name of the forum link to "forum" and not "help"
