Upgrade version from 2018.04 to 2019.04
Harpal Singh
Post by Harpal Singh » 21 Oct 2019, 12:47
Is it possible to upgrade current version to 2019.04?
I have updated my app`s existing version(2018.04) to 2019.04 but my app stopped working.
What should I do?
I shows the following exception in `/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Controller/CatalogController.php`
 ErrorException (E_WARNING)
Invalid argument supplied for foreach()
     * Returns the html for the catalog detail page.
     * @return \Illuminate\Http\Response Response object with output and headers
    public function detailAction()
        foreach( app( 'config' )->get( 'shop.page.catalog-detail' ) as $name )
            $params['aiheader'][$name] = Shop::get( $name )->getHeader();
            $params['aibody'][$name] = Shop::get( $name )->getBody();
        return Response::view( 'shop::catalog.detail', $params )
            ->header( 'Cache-Control', 'private, max-age=10' );
Harpal Singh
Re: Upgrade version from 2018.04 to 2019.04
Post by aimeos » 21 Oct 2019, 20:55
Between major versions (e.g. 2018 -> 2019) there are breaking changes:
https://aimeos.org/docs/Developers/Changelog/2019
You need to adapt your self written code and copied templates to that changes.
BTW: 2019.04 isn't supported any more, only 2019.10 LTS is now. Please have a look at the roadmap for the versioning scheme and the support periods: https://aimeos.org/roadmap
Harpal Singh
Post by Harpal Singh » 22 Oct 2019, 10:07
I have updated now to 2019.10 v, but now I am getting following ecxception.
Class 'Aimeos\MW\Session\Base' not found
Post by aimeos » 23 Oct 2019, 08:15
Seems like an incomplete update because the class is available in the 2019.10 release:
https://github.com/aimeos/aimeos-core/t ... MW/Session
