Created a new theme, but it is not recognized
Re: Created a new theme, but it is not recognized
Post by aimeos » 12 Nov 2025, 10:41
matish wrote: 10 Nov 2025, 14:30 Of course a huge load of files were also present under the ~/notebooks/views that are not included on my plugin (except for the base.blade.php). I am assuming that only those files need to be included, which are different from the default. If that is not the case, then I would say, it is not a very good design.
That's true, you only need the files you want to customize. The rest of the files are included for convenience and to have a stable layout if the original files change between versions.
matish wrote: 10 Nov 2025, 14:30 But end result is that it is not working.
If I copy ~/packages/notebooks/views/base.blade.php to /resources/views/vendor/shop/base.blade.php then it works immediately. Even without refreshing cache.
Copying the base.blade.php file to /resources/views/vendor/shop/base.blade.php will always use it regardless of the chosen theme, so this isn't the behavior you want. If you remove it again, can you please check:
- Your theme is selected in the "Settings" panel of the admin backend
- The theme is used here and your theme template is found: https://github.com/aimeos/aimeos-larave ... op.php#L82
If your theme template file isn't found, check the ExtensionServiceProvider class of your package.
matish
Post by matish » 12 Nov 2025, 11:11
Thanks for the information. I will check that later. Since there are huge load of files to change, I tried to take a different approach. Use API connection.
But, when I do
API request:
https://aimeos.priit.yt.lan/jsonapi/product?include=attribute%2Cmedia%2Cprice%2Cproduct%2Cproduct%2Fproperty%2Ctext%2Ccatalog%2Csupplier%2Cstock%2Cproperty&page%5Boffset%5D=0
Then I get back response like this:
Array
    [meta] => Array
            [total] => 13
            [prefix] =>
            [content-baseurl] =>
            [content-baseurls] => Array
                    [fs-media] => /aimeos
                    [fs-mimeicon] => /vendor/shop/mimeicons
                    [fs-theme] => /vendor/shop/themes
            [csrf] => Array
                    [name] => _token
                    [value] => 5gZTvIdOSCVF7wYwk2bV4UWsMrjFDABxOZpvCZE3
    [links] => Array
            [self] => https://aimeos.priit.yt.lan/jsonapi/product?include=attribute%2Cmedia%2Cprice%2Cproduct%2Cproduct%2Fproperty%2Ctext%2Ccatalog%2Csupplier%2Cstock%2Cproperty&page%5Boffset%5D=0
    [data] => Array
            [0] => Array
                    [id] => 52
                    [type] => product
                    [links] => Array
                            [self] => Array
                                    [href] => https://aimeos.priit.yt.lan/jsonapi/product?id=52
                                    [allow] => Array
                                            [0] => GET
                            [basket.product] => Array
                                    [href] => https://aimeos.priit.yt.lan/jsonapi/basket?id=default&related=product
                                    [allow] => Array
                                            [0] => POST
                    [attributes] => Array
                            [product.id] => 52
                            [product.url] => lenovo-thinkpad-t14-gen-4-i5-16gb-512gb-ssd
                            [product.type] => default
                            [product.code] => 21HD007H
                            [product.label] => Lenovo ThinkPad T14 Gen 4 - i5, 16GB,  512GB SSD
                            [product.status] => 1
                            [product.dataset] =>
                            [product.datestart] =>
                            [product.dateend] =>
                            [product.config] => Array
                            [product.scale] => 1
                            [product.target] =>
                            [product.ctime] => 2025-11-06 12:24:26
                            [product.ratings] => 0
                            [product.rating] => 0.00
                            [product.instock] => 0
                            [product.boost] => 1
                    [relationships] => Array
                            [product.property] => Array
                                    [data] => Array
                                            [0] => Array
                                                    [id] => 568
                                                    [type] => product.property
                                            [1] => Array
                                                    [id] => 569
                                            [2] => Array
                                                    [id] => 570
                                            [3] => Array
                                                    [id] => 571
                                            [4] => Array
                                                    [id] => 572
                                            [5] => Array
                                                    [id] => 573
                                            [6] => Array
                                                    [id] => 574
                                            [7] => Array
                                                    [id] => 575
                                            [8] => Array
                                                    [id] => 576
                                            [9] => Array
                                                    [id] => 577
                                            [10] => Array
                                                    [id] => 578
                                            [11] => Array
                                                    [id] => 579
                                            [12] => Array
                                                    [id] => 580
                                            [13] => Array
                                                    [id] => 581
                            [attribute] => Array
                                    [data] => Array
                                            [0] => Array
                                                    [id] => 7
                                                    [type] => attribute
                                                            [product.lists.id] => 540
                                                            [product.lists.domain] => attribute
                                                            [product.lists.refid] => 7
                                                            [product.lists.datestart] =>
                                                            [product.lists.dateend] =>
                                                            [product.lists.config] => Array
                                                            [product.lists.position] => 0
                                                            [product.lists.status] => 1
                                                            [product.lists.type] => default
                                            [1] => Array
                                                    [id] => 11
                                                    [type] => attribute
                                                            [product.lists.id] => 541
                                                            [product.lists.refid] => 11
                                            [2] => Array
                                                    [id] => 15
                                                    [type] => attribute
                                                            [product.lists.id] => 542
                                                            [product.lists.refid] => 15
                            [catalog] => Array
                                    [data] => Array
                                            [0] => Array
                                                    [id] => 2
                                                    [type] => catalog
                                                            [product.lists.id] => 543
                                                            [product.lists.domain] => catalog
                                                            [product.lists.refid] => 2
                                            [1] => Array
                                                    [id] => 5
                                                    [type] => catalog
                                                            [product.lists.id] => 544
                                                            [product.lists.refid] => 5
                            [media] => Array
                                    [data] => Array
                                            [0] => Array
                                                    [id] => 284
                                                    [type] => media
                                                            [product.lists.id] => 545
                                                            [product.lists.domain] => media
                                                            [product.lists.refid] => 284
                                            [1] => Array
                                                    [id] => 285
                                                    [type] => media
                                                            [product.lists.id] => 546
                                                            [product.lists.refid] => 285
                                            [2] => Array
                                                    [id] => 286
                                                    [type] => media
                                                            [product.lists.id] => 547
                                                            [product.lists.refid] => 286
                                            [3] => Array
                                                    [id] => 287
                                                    [type] => media
                                                            [product.lists.id] => 548
                                                            [product.lists.refid] => 287
                                            [4] => Array
                                                    [id] => 288
                                                    [type] => media
                                                            [product.lists.id] => 549
                                                            [product.lists.refid] => 288
                            [price] => Array
                                    [data] => Array
                                            [0] => Array
                                                    [id] => 52
                                                    [type] => price
                                                            [product.lists.id] => 550
                                                            [product.lists.domain] => price
                                                            [product.lists.refid] => 52
                            [text] => Array
                                    [data] => Array
                                            [0] => Array
                                                    [id] => 65
                                                    [type] => text
                                                            [product.lists.id] => 551
                                                            [product.lists.domain] => text
                                                            [product.lists.refid] => 65
                            [stock] => Array
                                    [data] => Array
                                            [0] => Array
                                                    [id] => 52
                                                    [type] => stock
            [1] => Array
                    [id] => 53
                    [type] => product
                    [links] => Array
                            [self] => Array
                                    [href] => https://aimeos.priit.yt.lan/jsonapi/product?id=53
                                    [allow] => Array
                                            [0] => GET
                                    [allow] => Array
                                            [0] => POST
                            [product.id] => 53
                            [product.url] => lenovo-thinkpad-t14-gen-4-i7-16gb-512gb-ssd
                            [product.code] => 1695374714
                            [product.label] => Lenovo ThinkPad T14 Gen 4 - i7, 16GB,  512GB SSD
                            [product.target] =>
                            [product.ctime] => 2025-11-06 12:24:35
                                    [data] => Array
                                            [0] => Array
                                                    [id] => 582
                                            [1] => Array
                                                    [id] => 583
                                            [2] => Array
                                                    [id] => 584
                                            [3] => Array
                                                    [id] => 585
                                            [4] => Array
                                                    [id] => 586
                                            [5] => Array
                                                    [id] => 587
                                            [6] => Array
                                                    [id] => 588
                                            [7] => Array
                                                    [id] => 589
                                            [8] => Array
                                                    [id] => 590
                                            [9] => Array
                                                    [id] => 591
                                            [10] => Array
                                                    [id] => 592
                                            [11] => Array
                                                    [id] => 593
                                            [12] => Array
                                                    [id] => 594
                                            [13] => Array
                                                    [id] => 595
                                            [14] => Array
                                                    [id] => 596
                                    [data] => Array
                                            [0] => Array
                                                    [id] => 7
                                                    [type] => attribute
                                                            [product.lists.id] => 552
                                            [1] => Array
                                                    [id] => 11
                                                    [type] => attribute
                                                            [product.lists.id] => 553
                                            [2] => Array
                                                    [id] => 15
                                                    [type] => attribute
                                                            [product.lists.id] => 554
                            [catalog] => Array
                                    [data] => Array
                                            [0] => Array
                                                    [id] => 2
                                                    [type] => catalog
                                                            [product.lists.id] => 555
                                            [1] => Array
                                                    [id] => 5
                                                    [type] => catalog
                                                            [product.lists.id] => 556
                            [media] => Array
                                    [data] => Array
                                            [0] => Array
                                                    [id] => 289
                                                    [type] => media
                                                            [product.lists.id] => 557
                                                            [product.lists.refid] => 289
                                            [1] => Array
                                                    [id] => 290
                                                    [type] => media
                                                            [product.lists.id] => 558
                                                            [product.lists.refid] => 290
                                            [2] => Array
                                                    [id] => 291
                                                    [type] => media
                                                            [product.lists.id] => 559
                                                            [product.lists.refid] => 291
                            [price] => Array
                                    [data] => Array
                                            [0] => Array
                                                    [id] => 53
                                                    [type] => price
                                                            [product.lists.id] => 560
                                                            [product.lists.refid] => 53
                            [text] => Array
                                    [data] => Array
                                            [0] => Array
                                                    [id] => 66
                                                    [type] => text
                                                            [product.lists.id] => 561
                                                            [product.lists.refid] => 66
                            [stock] => Array
                                    [data] => Array
                                            [0] => Array
                                                    [id] => 53
                                                    [type] => stock
    [included] => Array
            [0] => Array
                    [id] => 7
                    [type] => attribute
                            [attribute.id] => 7
                            [attribute.domain] => product
                            [attribute.type] => seisukord
                            [attribute.code] => seiukord_uus
                            [attribute.label] => Uus
                            [attribute.status] => 1
                            [attribute.position] => 1
                            [text] => Array
                                    [data] => Array
                                            [0] => Array
                                                    [id] => 2
                                                    [type] => text
                                                            [attribute.lists.id] => 1
                                                            [attribute.lists.domain] => text
                                                            [attribute.lists.refid] => 2
                                                            [attribute.lists.datestart] =>
                                                            [attribute.lists.dateend] =>
                                                            [attribute.lists.config] => Array
                                                            [attribute.lists.position] => 0
                                                            [attribute.lists.status] => 1
                                                            [attribute.lists.type] => default
            [46] => Array
                    [id] => 284
                    [type] => media
                            [media.id] => 284
                            [media.filesystem] => fs-media
                            [media.domain] => product
                            [media.languageid] =>
                            [media.mimetype] => image/jpeg
                            [media.type] => default
                            [media.preview] => 1.d/product/3/9/39139083_8b60d6d9_original_2__2.webp?v=20251106122421
                            [media.previews] => Array
                                    [240] => 1.d/product/3/9/39139083_8b60d6d9_original_2__2.webp
                                    [480] => 1.d/product/b/e/be0da88d_8b60d6d9_original_2__2.webp
                                    [960] => 1.d/product/8/d/8dc9fa3a_8b60d6d9_original_2__2.webp
                                    [1920] => 1.d/product/4/3/4384cae8_8b60d6d9_original_2__2.webp
                            [media.url] => 1.d/product/8/b/8b60d6d9_original_2__2.jpg
                            [media.status] => 1
            [47] => Array
                    [id] => 285
                    [type] => media
                            [media.id] => 285
                            [media.preview] => 1.d/product/5/5/5555a1eb_6098da94_original_1__1.webp?v=20251106122422
                                    [240] => 1.d/product/5/5/5555a1eb_6098da94_original_1__1.webp
                                    [480] => 1.d/product/0/e/0e0c5acb_6098da94_original_1__1.webp
                                    [960] => 1.d/product/8/7/876417dd_6098da94_original_1__1.webp
                                    [1920] => 1.d/product/e/c/ecede971_6098da94_original_1__1.webp
                            [media.url] => 1.d/product/6/0/6098da94_original_1__1.jpg
                            [media.status] => 1
            [314] => Array
                    [id] => 63
                    [type] => stock
                            [stock.id] => 63
                            [stock.productid] => 63
                            [stock.stocklevel] => 0
                            [stock.timeframe] =>
                            [stock.dateback] =>
                            [stock.type] => default
                    [links] => Array
                            [self] => Array
                                    [href] => https://aimeos.priit.yt.lan/jsonapi/stock?id=63
                                    [allow] => Array
                                            [0] => GET
            [315] => Array
                    [id] => 64
                    [type] => stock
                            [stock.id] => 64
                            [stock.productid] => 64
                            [stock.dateback] =>
                    [links] => Array
                            [self] => Array
                                    [href] => https://aimeos.priit.yt.lan/jsonapi/stock?id=64
                                    [allow] => Array
                                            [0] => GET
As it can be seen, the response lacks Media URLs that can be accessed directly. Instead it has links like this:
How can I get direct links to Media. I only have http/https access.
Post by aimeos » 12 Nov 2025, 11:15
Set the ASSET_URL/APP_URL in your application correctly:
https://github.com/aimeos/aimeos-larave ... op.php#L77
Then, you get the base URL in the meta/content-baseurl property.
matish
Post by matish » 12 Nov 2025, 12:52
This setting does not change the response, but I can see that top part changes.
response[meta][content-baseurls][fs-media] = https://aimeos.priit.yt.lan/aimeos
I guess that if I prefix the '1.d/product/5/5/5555a1eb_6098da94_original_1__1.webp' with the above, then maybe I get what I want.
Also discovered another thing. How can I get product Property name labels, the ones that are surrounded with green on the attached screenshot.
They do not seem to be included in API response.
matish
Post by matish » 12 Nov 2025, 13:04
Actually the same applies to both Product properties and Product attributes.
Post by aimeos » 14 Nov 2025, 10:22
matish wrote: 12 Nov 2025, 12:52 This setting does not change the response, but I can see that top part changes.
Exactly.
matish wrote: 12 Nov 2025, 12:52 Also discovered another thing. How can I get product Property name labels, the ones that are surrounded with green on the attached screenshot. They do not seem to be included in API response.
The data is only included on request:
https://laravel.demo.aimeos.org/jsonapi ... perty/type
Same applies to product attributes and types:
https://laravel.demo.aimeos.org/jsonapi ... ibute/type
matish
Post by matish » 20 Nov 2025, 21:35
Altered the include attribute to on the request to:
attribute,media,price,product,product/property,text,catalog,supplier,stock,property,product/property/type,attribute/type
Missing pieces that were not included on the documentation were the product/property/type and attribute/type
Now I am getting all the data that is needed and can continue further with the testing. Thanks!
