Override Aimeos templates
hajatiana.randria
Post by hajatiana.randria » 23 Jun 2020, 08:53
Hello all,
I'm trying to override the front aimeos template.
I tried to copy the files in ./ext in ./ext/my-new-ext but nothing. Did I miss something?
if anyone can guide me it would be great.
php version 7.2
aimeos-laravel: 2020.04
Environnement: WIndows 10
thank you in advance.
Re: Override Aimeos templates
Post by aimeos » 23 Jun 2020, 17:38
In which directory did you copy the files? Please keep in mind, they need to be in the same directory structure as in the original extension.
hajatiana.randria
Post by hajatiana.randria » 23 Jun 2020, 18:13
I did as on the attached image.Image
Post by aimeos » 23 Jun 2020, 20:40
That's totally wrong, create your new extension here: https://aimeos.org/extensions
hajatiana.randria
Post by hajatiana.randria » 24 Jun 2020, 08:43
Hello
it's OK
