Add global scope on retrieving products
GagDalakyan
Post by GagDalakyan » 02 Aug 2021, 07:25
Laravel : 8.4
Aimeos : 2021.04
PHP Version : 7.4
Environment : Windows
Good day. I need to add global scope for products in frontend ( Product lists, detail page, bought together products, etc. ) , for example
 $productManager->compare( '==', 'product.config', 'visibility":"1' );
Can anyone help ?
I see there is a similar global scope on product status in frontend manager ( product.status = 1 ).
I need to add something similar to this to add my scope.
Thanks a lot!
Re: Add global scope on retrieving products
Post by aimeos » 03 Aug 2021, 13:32
The easiest solution is to add a mshop_product.visibility column and extend the product manager with a decorator to make the column known to Aimeos:
https://aimeos.org/docs/latest/models/extend-managers/
GagDalakyan
Post by GagDalakyan » 03 Aug 2021, 15:11
Thanks for reply!
Im sorry.I asked wrong question.
I need to show in frontend for example only products where ( '>', 'product.rating', '2' );
Rating column is already in mshop_product table. How i can add this rule in all queries?
Post by aimeos » 04 Aug 2021, 06:01
filter[>][product.rating]=2
// escaped
filter[%3E][product.rating]=2
GagDalakyan
Post by GagDalakyan » 04 Aug 2021, 06:09
And where add this filter ?
Post by aimeos » 04 Aug 2021, 06:13
Sorry, that was for the JSON API. When using the product manager directly, you should use:
$filter = $manager->filter( true )->add( 'product.rating', '>', 2 );
$items = $manager->search( $filter );
GagDalakyan
Post by GagDalakyan » 04 Aug 2021, 08:56
Thanks for your reply.
I understand. But i want to know is there a way, to add it global to product manager class( as product status is always set to 1 ), not every time add this filter while using product manager.
Post by aimeos » 05 Aug 2021, 05:49
Create a new product manager that extends from the original one, overwrite the filter() method and add your condition there:
https://github.com/aimeos/aimeos-core/b ... #L280-L328
GagDalakyan
Post by GagDalakyan » 05 Aug 2021, 07:15
Many thanks.
And my last question. ))
This works fine, but does not affect to similar products and products bought together in product detail. Any suggestions ?
Post by aimeos » 05 Aug 2021, 15:19
You have to overwrite the isAvailable() method of the product item too:
https://github.com/aimeos/aimeos-core/b ... #L444-L449
See also:
https://aimeos.org/docs/latest/models/e ... custom-way
