Filtering Description
Re: Filtering Description
Post by aimeos » 25 Nov 2021, 14:00
Post by aimeos » 26 Nov 2021, 17:50
Your text is a bad example because it has a language ID of NULL and thus it's not added to the index. We will fix that in the next release. Just assign a language ID to your text for the moment.
Post by aimeos » 26 Nov 2021, 18:22
I've seen that texts with language ID NULL are already added to the index.
Is your example text to stored in the mshop_index_text table after you save the product in the backend?
