add colum users table and all work fine now
ttcode
Post by ttcode » 08 May 2022, 10:45
All done.
My biggest problem was adding a column to the users table, but everything works fine now. Now I can edit, save and view user data from both front and back.
I had to modify a lot of things to add a simple column to the users table and everything would work fine.
I had problems that when the user changed his data, the content of the new column was deleted, but everything is fine.
I didn't need anyone's help but thanks anyway.
this alls files i add code for add colum to table users and do this save , show , edit , and new all ok.
vendor/aimeos/ai-laravel/lib/custom/config/mshop/customer.php
vendor/aimeos/ai-laravel/lib/custom/src/MShop/Customer/Manager/Laravel.php
vendor/aimeos/ai-admin-jqadm/admin/jqadm/src/Admin/JQAdm/Customer/Standard.php
vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Common/Item/Address/Iface.php
vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Common/Item/Address/Base.php
vendor/aimeos/ai-admin-jqadm/admin/jqadm/templates/customer/item-standard.php
vendor/aimeos/ai-admin-jqadm/admin/jqadm/templates/customer/list-standard.php
vendor/aimeos/ai-client-html/client/html/templates/account/profile/address-body-standard.php
:ugeek:
https://ibb.co/jr663nC
Re: add colum users table and all work fine now
Post by aimeos » 09 May 2022, 13:42
If you create a decorator for the customer manager, it's much easier because then, you only have to create your manager decorator, configure it and adapt the template files:
See here for details:
https://aimeos.org/docs/latest/models/e ... /#easy-way
