How to change the breakpoint for the mobile menu
yeh
Post by yeh » 27 Jul 2022, 08:24
Hi, is it possible to change the breakpoint to show the mobile menu?
I would like to show the mobile menu on all devices.
Re: How to change the breakpoint for the mobile menu
Post by aimeos » 28 Jul 2022, 04:52
You should create an own theme and choose it in the backend for your site:
https://aimeos.org/docs/latest/laravel/themes/
In that theme, remove this method in your theme catalog-filter.js file:
https://github.com/aimeos/ai-client-htm ... js#L16-L71
Also, remove these lines in the CSS file of your own theme:
https://github.com/aimeos/ai-client-htm ... #L594-L713
https://github.com/aimeos/ai-client-htm ... r.css#L723
yeh
Post by yeh » 28 Jul 2022, 09:11
Brilliant, those instructions really helped. There are also two more things needed to get this fully working:
1. remove the media query around the cat-link display statements so that the desktop menu links are hidden when the menu opens
https://github.com/aimeos/ai-client-htm ... r.css#L563
2. Comment out this.onMenuHover(); from the init() method
https://github.com/aimeos/ai-client-htm ... er.js#L310
Thanks again
