Improvements to the front end
NathanGibson
Post by NathanGibson » 27 Sep 2022, 01:48
Hello, where should I make some adjustments to the Frontend design? Can I update the vendor folder with my changes? If I can, I will ensure that my changes are preserved when the vendor is updated or they will be lost after the update. Would you kindly offer some suggestions?
Re: Improvements to the front end
Post by aimeos » 28 Sep 2022, 10:57
Don't change anything in the vendor folder because your changes would be overwritten with the next update.
Instead, create your own theme. For Laravel, you can find documentation here:
https://aimeos.org/docs/latest/laravel/themes/
