The aggregation limit does not work if more than 10000 is set in the configs
I found some config issues, https://aimeos.org/docs/latest/config/m ... #aggregate
when I set a limit greater than 10000 for "mshop/common/manager/aggregate/limit" config it doesn't work due to checking the minimum value here https://github.com/aimeos/aimeos-core/b ... e.php#L302
Can there be any problems if we just remove the check for the minimum value, or maybe need to set something else in the configuration?
Re: The aggregation limit does not work if more than 10000 is set in the configs
"mshop/common/manager/aggregate/limit" is the maximum allowed number of items in an aggregation but the actual number of items that should be used is passed in the filter by the component which calls aggregate().
