Difficulty Adding a Custom Field in Aimeos Models Item and Issues with Saving
unknow76616
Post by unknow76616 » 26 Nov 2023, 17:34
I am currently working on extending the Aimeos e-commerce framework by adding a custom field to the order item. I have successfully created the corresponding database column by overwriting order.php file in the setup/default/schema directory. Additionally, I've declared the necessary setter and getter methods for the new field in the Standard.php file located in MShop/Order/Item.
I've followed the suggestions provided by a fellow member in a related forum post post5939.html However, I'm encountering difficulties in saving the new field using
$manager->save(...)
. Despite attempting various implementations, the data doesn't persist when using this method.
I had to with using
$context->db()->update(...)
after the default
$manager->save(...)
, but this approach involves two separate database transactions, which is not an ideal solution.
I would greatly appreciate any guidance or insights from the community on the best practices for adding custom fields to the order item and ensuring their successful persistence using the
$manager->save(...)
method.
php8.1 , laravel, linux
Re: Difficulty Adding a Custom Field in Aimeos Models Item and Issues with Saving
Post by aimeos » 27 Nov 2023, 11:53
It's much simpler, just read this article:
https://aimeos.org/docs/latest/models/extend-managers/
