Unit tests
Gagik
Unit tests
Post by Gagik » 06 Dec 2023, 06:36
PHP version: 8.1
Laravel version: 10
Aimeos version: 2023.07
Environment: Linux
Where can I find topics/documentation/open source projects about Unit Tests?
With small example like in the documentation for Unit Tests in Laravel (https://laravel.com/docs/10.x/testing)
For example how to test "Add to basket" action via Aimeos Unit Tests
Re: Unit tests
Post by aimeos » 08 Dec 2023, 09:03
There's a small article about the build system incl. test target:
https://aimeos.org/docs/latest/developer/phing/
If you want to test your extension:
1.) check out aimeos/aimeos-core
2.) adapt the ./config/resource.php (copy from .dist file)
3.) run "composer up"
4.) place your extension in the ./ext/ directory
5.) run "vendor/bin/phing -Ddir=ext/<yourext> setup testext
