Admin panel vue js methods
Gagik
Post by Gagik » 12 Dec 2023, 11:40
PHP version: 8.1
Laravel version: 10
Aimeos version: 2023.10
Environment: Linux
I have seen some vue js methods used in admin panel templates.
For example method " v-on:click="toggle('_ext', idx)" " in the \ai-admin-jqadm\templates\admin\jqadm\catalog\item-media.php
Where can I create new method(s) like that method ?
Re: Admin panel vue js methods
Post by aimeos » 14 Dec 2023, 08:30
You can add own methods to JS objects in the custom.js file of your own extension which you can use in the templates afterwards: https://aimeos.org/docs/latest/admin/jqadm/customize/
