Reviewerror and Pictureerror
Shopmister
Re: Reviewerror and Pictureerror
Post by Shopmister » 07 Jun 2021, 08:06
Can you create a short video showing the problem? We need to know what exactly are you doing (before).
here are the video:
https://www.dropbox.com/s/23cnc2xclufq3 ... 3.mp4?dl=0
The next minor release will be in ca. two weeks.
Okay, i hope then are without any bugs for typo3 ^^. It was better by every new version. I hope its anough fixed now :)
There's the commit history of the packages where you can see the changes. For each non-minor (bugfix) release, we are also publishing a blog article and send a newsletter with the most important changes.
What is a commit history?
Post by aimeos » 08 Jun 2021, 07:18
That's very strange as TYPO3 doesn't remove the exclamation marks after you've selected the page. Does this only occur if you edit existing plugins, only when adding new ones or both? Which TYPO3 version are you using?
Shopmister wrote: 07 Jun 2021, 08:06 What is a commit history?
e.g.: https://github.com/aimeos/aimeos-typo3/commits/master
Shopmister
Post by Shopmister » 09 Jul 2021, 06:33
i see in the current version that you fixed it, thanks.
