Reviewerror and Pictureerror
Shopmister
Post by Shopmister » 24 May 2021, 13:51
TYPO3 Version 10.4.13
Webserver Apache
PHP Version 7.3.27-1~deb10u1
Database (Default) MySQL 5.5.5-10.3.27-MariaDB-0+deb10u1
Application Context Production
Operating System Linux 4.19.0-9-amd64
Last Scheduler run 24-05-21 at 15:36, Duration 0 min, (started automatically)
aimeos 21.4.2
Hey,
1) This error if i save an review to enable. it will enabled after it in backend. but i cant see an review in frontend. in last versions i only did see the stars. And not the reviewtext. Now i dont see reviews in frontend at the detailpage, anymore.
2) And if i save an image for the product. but only maybe if its a small. for most pictures it works.
Argument 3 passed to Aimeos\MShop\Product\Manager\Standard::rate() must be of the type int, null given
in /home/users/outsource/www/Shop/Firsttestnew/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-core/lib/mshoplib/src/MShop/Product/Manager/Standard.php line 472
* @param string $rating Decimal value of the rating
* @param int $ratings Total number of ratings for the item
* @return \Aimeos\MShop\Common\Manager\Iface Manager object for chaining method calls
public function rate( string $id, string $rating, int $ratings ) : \Aimeos\MShop\Common\Manager\Iface
$dbm = $context->getDatabaseManager();
at Aimeos\MShop\Product\Manager\Standard->rate('5', 'NAN', null)
at call_user_func_array(array(object(Aimeos\MShop\Product\Manager\Standard), 'rate'), array('5', NAN, null))
in /home/users/outsource/www/Shop/Firsttestnew/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-core/lib/mshoplib/src/MShop/Common/Manager/Decorator/Base.php line 51
* @throws \Aimeos\MShop\Exception If method call failed
public function __call( string $name, array $param )
return call_user_func_array( array( $this->manager, $name ), $param );
at Aimeos\MShop\Common\Manager\Decorator\Base->__call('rate', array('5', NAN, null))
in /home/users/outsource/www/Shop/Firsttestnew/typo3conf/ext/aimeos/Resources/Private/Extensions/ai-admin-jqadm/admin/jqadm/src/Admin/JQAdm/Review/Standard.php line 416
$rateManager = \Aimeos\MShop::create( $context, $item->getDomain() );
if( $entry = $manager->aggregate( $filter, 'review.refid', 'review.rating', 'rate' )->first() ) {
$rateManager->rate( $item->getRefId(), $entry['sum'] / $entry['count'], $entry['count'] );
} else {
$rateManager->rate( $item->getRefId(), 0, 0 );
at Aimeos\Admin\JQAdm\Review\Standard->update(array(object(Aimeos\MShop\Review\Item\Standard)))
in /home/users/outsource/www/Shop/Firsttestnew/typo3conf/ext/aimeos/Resources/Private/Extensions/ai-admin-jqadm/admin/jqadm/src/Admin/JQAdm/Review/Standard.php line 126
$item = $manager->save( clone $view->item );
$manager->commit();
return $this->update( [$item] )->redirect( 'review', $view->param( 'next' ), $view->item->getId(), 'save' );
catch( \Exception $e )
$manager->rollback();
i pasted for the old database before i installed aimeos: to the tableoptions in localconf:
'charset' => 'utf8',
'collate' => 'utf8_unicode_ci',
More error:
at Aimeos\Admin\JQAdm\Review\Standard->save()
in /home/users/outsource/www/Shop/Firsttestnew/typo3conf/ext/aimeos/Resources/Private/Extensions/ai-admin-jqadm/admin/jqadm/src/Admin/JQAdm/Common/Decorator/Base.php line 128
* @return string|null HTML output
public function save() : ?string
return $this->client->save();
at Aimeos\Admin\JQAdm\Common\Decorator\Base->save()
in /home/users/outsource/www/Shop/Firsttestnew/typo3conf/ext/aimeos/Classes/Controller/JqadmController.php line 187
public function saveAction()
$cntl = $this->createAdmin();
if( ( $html = $cntl->save() ) == '' ) {
return $this->setPsrResponse( $cntl->getView()->response() );
$this->view->assign( 'content', $html );
at Aimeos\Aimeos\Controller\JqadmController->saveAction()
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/extbase/Classes/Mvc/Controller/ActionController.php line 498
$validationResult = $this->arguments->validate();
if (!$validationResult->hasErrors()) {
$this->eventDispatcher->dispatch(new BeforeActionCallEvent(static::class, $this->actionMethodName, $preparedArguments));
$actionResult = $this->{$this->actionMethodName}(...$preparedArguments);
} else {
$actionResult = $this->{$this->errorMethodName}();
at TYPO3\CMS\Extbase\Mvc\Controller\ActionController->callActionMethod()
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/extbase/Classes/Mvc/Controller/ActionController.php line 426
$this->view = $this->resolveView();
if ($this->view !== null) {
$this->initializeView($this->view);
$this->callActionMethod();
$this->renderAssetsForRequest($request);
at TYPO3\CMS\Extbase\Mvc\Controller\ActionController->processRequest(object(TYPO3\CMS\Extbase\Mvc\Web\Request), object(TYPO3\CMS\Extbase\Mvc\Web\Response))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/extbase/Classes/Mvc/Dispatcher.php line 89
throw new InfiniteLoopException('Could not ultimately dispatch the request after ' . $dispatchLoopCount . ' iterations. Most probably, a @' . IgnoreValidation::class . ' annotation is missing on re-displaying a form with validation errors.', 1217839467);
$controller = $this->resolveController($request);
try {
$controller->processRequest($request, $response);
} catch (StopActionException $ignoredException) {
at TYPO3\CMS\Extbase\Mvc\Dispatcher->dispatch(object(TYPO3\CMS\Extbase\Mvc\Web\Request), object(TYPO3\CMS\Extbase\Mvc\Web\Response))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/extbase/Classes/Mvc/Web/BackendRequestHandler.php line 36
$request = $this->requestBuilder->build();
/** @var \TYPO3\CMS\Extbase\Mvc\ResponseInterface $response */
$response = $this->objectManager->get(Response::class);
$this->dispatcher->dispatch($request, $response);
return $response;
at TYPO3\CMS\Extbase\Mvc\Web\BackendRequestHandler->handleRequest()
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/extbase/Classes/Core/Bootstrap.php line 226
$this->initialize($configuration);
$requestHandler = $this->requestHandlerResolver->resolveRequestHandler();
/** @var ExtbaseResponse $extbaseResponse */
$extbaseResponse = $requestHandler->handleRequest();
// Convert to PSR-7 response and hand it back to TYPO3 Core
$response = $this->convertExtbaseResponseToPsr7Response($extbaseResponse);
$this->resetSingletons();
at TYPO3\CMS\Extbase\Core\Bootstrap->handleBackendRequest(object(TYPO3\CMS\Core\Http\ServerRequest))
at call_user_func_array(array(object(TYPO3\CMS\Extbase\Core\Bootstrap), 'handleBackendRequest'), array(object(TYPO3\CMS\Core\Http\ServerRequest)))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/backend/Classes/Http/RouteDispatcher.php line 66
$targetIdentifier = $route->getOption('target');
$target = $this->getCallableFromTarget($targetIdentifier);
$arguments = [$request];
return call_user_func_array($target, $arguments);
* Wrapper method for static form protection utility
at TYPO3\CMS\Backend\Http\RouteDispatcher->dispatch(object(TYPO3\CMS\Core\Http\ServerRequest))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/backend/Classes/Http/RequestHandler.php line 94
// there are Core classes that need the Request object but do not get it handed in
$this->resetGlobalsToCurrentRequest($request);
try {
// Check if the router has the available route and dispatch.
return $this->dispatcher->dispatch($request);
} catch (InvalidRequestTokenException $e) {
// When token was invalid redirect to login
$loginPage = GeneralUtility::makeInstance(UriBuilder::class)->buildUriFromRoute('login');
return new RedirectResponse((string)$loginPage);
at TYPO3\CMS\Backend\Http\RequestHandler->handle(object(TYPO3\CMS\Core\Http\ServerRequest))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/extbase/Classes/Middleware/SignalSlotDeprecator.php line 49
public function process(ServerRequestInterface $request, RequestHandlerInterface $handler): ResponseInterface
$this->dispatcher->reportDeprecatedSignalSlots();
return $handler->handle($request);
at TYPO3\CMS\Extbase\Middleware\SignalSlotDeprecator->process(object(TYPO3\CMS\Core\Http\ServerRequest), object(TYPO3\CMS\Backend\Http\RequestHandler))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php line 172
if (!$middleware instanceof MiddlewareInterface) {
throw new \InvalidArgumentException(get_class($middleware) . ' does not implement ' . MiddlewareInterface::class, 1516821342);
return $middleware->process($request, $this->next);
at class@anonymous/home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php0x7f1cfaa0241b->handle(object(TYPO3\CMS\Core\Http\ServerRequest))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/backend/Classes/Middleware/SiteResolver.php line 69
$site = $this->siteMatcher->matchByPageId($pageId, $rootLine);
$request = $request->withAttribute('site', $site);
at TYPO3\CMS\Backend\Middleware\SiteResolver->process(object(TYPO3\CMS\Core\Http\ServerRequest), object(class@anonymous/home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php0x7f1cfaa0241b))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/backend/Classes/Middleware/AdditionalResponseHeaders.php line 41
* @return ResponseInterface
$response = $handler->handle($request);
foreach ($GLOBALS['TYPO3_CONF_VARS']['BE']['HTTP']['Response']['Headers'] ?? [] as $header) {
[$headerName, $value] = explode(':', $header, 2);
$response = $response->withAddedHeader($headerName, trim($value));
at TYPO3\CMS\Backend\Middleware\AdditionalResponseHeaders->process(object(TYPO3\CMS\Core\Http\ServerRequest), object(class@anonymous/home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php0x7f1cfaa0241b))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/backend/Classes/Middleware/OutputCompression.php line 47
ob_clean();
// Initialize output compression if configured
$this->initializeOutputCompression();
* Initialize output compression if configured
at TYPO3\CMS\Backend\Middleware\OutputCompression->process(object(TYPO3\CMS\Core\Http\ServerRequest), object(class@anonymous/home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php0x7f1cfaa0241b))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/backend/Classes/Middleware/BackendUserAuthenticator.php line 78
$GLOBALS['LANG'] = LanguageService::createFromUserPreferences($GLOBALS['BE_USER']);
// Re-setting the user and take the workspace from the user object now
$this->setBackendUserAspect($GLOBALS['BE_USER']);
// If no backend user is logged-in, the cookie should be removed
if (!GeneralUtility::makeInstance(Context::class)->getAspect('backend.user')->isLoggedIn()) {
$GLOBALS['BE_USER']->removeCookie($GLOBALS['BE_USER']->name);
at TYPO3\CMS\Backend\Middleware\BackendUserAuthenticator->process(object(TYPO3\CMS\Core\Http\ServerRequest), object(class@anonymous/home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php0x7f1cfaa0241b))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/backend/Classes/Middleware/BackendRouteInitialization.php line 58
// Add the route path to the request
$request = $request->withAttribute('routePath', $pathToRoute);
at TYPO3\CMS\Backend\Middleware\BackendRouteInitialization->process(object(TYPO3\CMS\Core\Http\ServerRequest), object(class@anonymous/home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php0x7f1cfaa0241b))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/backend/Classes/Middleware/ForcedHttpsBackendRedirector.php line 55
[$server, $address] = explode('/', $url, 2);
return new RedirectResponse('https://' . $server . $sslPortSuffix . '/' . $address);
at TYPO3\CMS\Backend\Middleware\ForcedHttpsBackendRedirector->process(object(TYPO3\CMS\Core\Http\ServerRequest), object(class@anonymous/home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php0x7f1cfaa0241b))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/backend/Classes/Middleware/LockedBackendGuard.php line 75
$request->getAttribute('normalizedParams')->getRemoteAddress(),
trim((string)$GLOBALS['TYPO3_CONF_VARS']['BE']['IPmaskList'])
* Check adminOnly configuration variable and redirects to an URL in file typo3conf/LOCK_BACKEND
at TYPO3\CMS\Backend\Middleware\LockedBackendGuard->process(object(TYPO3\CMS\Core\Http\ServerRequest), object(class@anonymous/home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php0x7f1cfaa0241b))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/core/Classes/Middleware/NormalizedParamsAttribute.php line 45
$request = $request->withAttribute('normalizedParams', NormalizedParams::createFromRequest($request));
at TYPO3\CMS\Core\Middleware\NormalizedParamsAttribute->process(object(TYPO3\CMS\Core\Http\ServerRequest), object(class@anonymous/home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php0x7f1cfaa0241b))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php line 78
public function handle(ServerRequestInterface $request): ResponseInterface
return $this->tip->handle($request);
* Seed the middleware stack with the inner request handler
at TYPO3\CMS\Core\Http\MiddlewareDispatcher->handle(object(TYPO3\CMS\Core\Http\ServerRequest))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/core/Classes/Http/AbstractApplication.php line 85
protected function handle(ServerRequestInterface $request): ResponseInterface
return $this->requestHandler->handle($request);
* Set up the application and shut it down afterwards
at TYPO3\CMS\Core\Http\AbstractApplication->handle(object(TYPO3\CMS\Core\Http\ServerRequest))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/backend/Classes/Http/Application.php line 72
$request = $request->withAttribute('applicationType', $applicationType);
// Set up the initial context
$this->initializeContext();
return parent::handle($request);
* Check if LocalConfiguration.php and PackageStates.php exist
at TYPO3\CMS\Backend\Http\Application->handle(object(TYPO3\CMS\Core\Http\ServerRequest))
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/sysext/core/Classes/Http/AbstractApplication.php line 97
final public function run(callable $execute = null)
try {
$response = $this->handle(
ServerRequestFactory::fromGlobals()
if ($execute !== null) {
call_user_func($execute);
at TYPO3\CMS\Core\Http\AbstractApplication->run()
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/index.php line 25
// Set up the application for the backend
call_user_func(function () {
$classLoader = require dirname(__DIR__).'/vendor/autoload.php';
\TYPO3\CMS\Core\Core\SystemEnvironmentBuilder::run(1, \TYPO3\CMS\Core\Core\SystemEnvironmentBuilder::REQUESTTYPE_BE);
\TYPO3\CMS\Core\Core\Bootstrap::init($classLoader)->get(\TYPO3\CMS\Backend\Http\Application::class)->run();
at {closure}()
in /home/users/outsource/www/typo3_sources/typo3_src-10.4.13/typo3/index.php line 26
Re: Reviewerror and Pictureerror
Post by aimeos » 28 May 2021, 17:45
Thanks for your bug report. Can you post a screenshot of the content of your mshop_review table, please?
Shopmister
Post by Shopmister » 29 May 2021, 04:05
Here the screenshot of the table
Post by aimeos » 30 May 2021, 06:55
We've fixed the problem and it will be part of the next release.
Shopmister
Post by Shopmister » 30 May 2021, 08:19
Nice, but wich problem exactly. the error for saving reviewstatus and if uploading different imagesizes
or
the problem that i have no reviews in frontend. because before in last versions and without changing that:
because for older databases, it was a review with stars but not with text. only stars. And now they arent with both anymore :)
Ps. Maybe a cssproblem by me or so. But i think in the accountview its not possible to click the downloaded productlink (the curser is hand then). the ordertab is only closing then :)
Post by aimeos » 30 May 2021, 09:53
The problem of saving a review in the backend and that they are not shown in the frontend.
What's the problem with uploading different image sizes?
Shopmister
Post by Shopmister » 30 May 2021, 11:17
Very nice :)
It was the same error(errorcode i dont know) like the saving error by reviews. But i cant reconstruate atm.
Maybe it never come again, and if really was same errorcode, its away at the next AImeos Version :)
Can i tell short another problem without having to do with that. Its not a big problem and maybe not easy to find a solution but:
if i save aimeos content elements/plugins first time are always at half around of fields to fill /insert siteids an red Exclamation mark. I cant save then for sure. i have to switch the plugin and switch back. And if i filled before all fields i can save now. if i forgot one, i have to fill this one and switch again the plugin and back :). It only hit the nerves a bit, but isnt a big problem hehe.
Post by aimeos » 03 Jun 2021, 09:12
Shopmister wrote: 30 May 2021, 11:17
If you see an error message, always look into the Log panel to see the error details.
Shopmister wrote: 30 May 2021, 11:17 Can i tell short another problem without having to do with that. Its not a big problem and maybe not easy to find a solution but:
This is normal as the Aimeos plugins declare a few fields are required. TYPO3 marks them accordingly and don't let you save the plugin before you didn't fill the required fields.
Shopmister
Post by Shopmister » 06 Jun 2021, 05:41
No its only by the AImeos extension. That it let me dont save before i filled all "and" choose another plugin and switch back. Normally in typo3 if i filled all it can be saved. Not by all versions i used from aimeos in around last one or two years. Like i said, its not really a big problem but its buggy :)
Ps. Do you know when the next Aimeos update comes? Maybe i wait then for next and hope there will al working. Because i tryed one time to update an Aimeos version, and i remember that soemthing went really wrong ^^. Buts maybe in newer Versions not a problem anymore :)
Ps.2 Where i cant find e datailed Changelog from aimeos? like typo3 has.
Post by aimeos » 07 Jun 2021, 06:52
Shopmister wrote: 06 Jun 2021, 05:41 No its only by the AImeos extension. That it let me dont save before i filled all "and" choose another plugin and switch back. Normally in typo3 if i filled all it can be saved. Not by all versions i used from aimeos in around last one or two years. Like i said, its not really a big problem but its buggy :)
Can you create a short video showing the problem? We need to know what exactly are you doing (before).
Shopmister wrote: 06 Jun 2021, 05:41 Ps. Do you know when the next Aimeos update comes? Maybe i wait then for next and hope there will al working. Because i tryed one time to update an Aimeos version, and i remember that soemthing went really wrong ^^. Buts maybe in newer Versions not a problem anymore :)
The next minor release will be in ca. two weeks.
Shopmister wrote: 06 Jun 2021, 05:41 Ps.2 Where i cant find e datailed Changelog from aimeos? like typo3 has.
There's the commit history of the packages where you can see the changes. For each non-minor (bugfix) release, we are also publishing a blog article and send a newsletter with the most important changes.
