watermark - uri - preselect
goransabo
Post by goransabo » 17 Dec 2020, 12:47
Hello!
I need to add watermark to all images!
How and where can I do it?
How to change url's:
currently: /product/d/product-name/0
need to be: /product/product-name
In all products I have 3 possible intervals.
How can I add (in select) first option by default/preselect.
1st: 4 weeks
2nd: 8 weeks
3rd: 13 weeks
Order in select must be like described above!
Thank all for help!
Goran
// Typo3 10.4.11 / Aimeos 20.10.4 / PHP 7.3 //
goransabo
Re: watermark - uri - preselect
Post by goransabo » 17 Dec 2020, 16:32
I have fixed preselect, but can't fix order by position (in admin Attributes -> Position)
Post by aimeos » 18 Dec 2020, 08:45
goransabo wrote: 17 Dec 2020, 12:47 I need to add watermark to all images!
It's described there: https://aimeos.org/tips/aimeos-2019-10-lts-release/
goransabo wrote: 17 Dec 2020, 12:47 How to change url's:
You need to use your own route enhancer rules and limit them to a specific page. To remove the "/x", configure the catalog/stage component without navigator subpart:
https://aimeos.org/docs/2020.x/config/c ... /#subparts
goransabo wrote: 17 Dec 2020, 12:47 In all products I have 3 possible intervals.
1st: 4 weeks
2nd: 8 weeks
3rd: 13 weeks
The order of the entries is determined by the position value of the attribute which you can change in the attribute panel of the admin backend.
goransabo
Post by goransabo » 18 Dec 2020, 17:58
:-) ok!!
I have tried everything, but without success!
I don't know what and where I do with it ...!:
controller/common/media/standard/options/image/watermark = /path/to/image.png
controller/common/media/standard/options/image/name = Imagick
The same problem have with url!
I have added:
plugin.tx_aimeos.settings.client.html.catalog.stage.standard.subparts = this is ok
now I have product/d/product-name
How to remove /d/ form url?
More help!! :-)
Thank's & Best regards,
Goran
Post by aimeos » 20 Dec 2020, 13:34
goransabo wrote: 18 Dec 2020, 17:58 I have tried everything, but without success!
Please read this article for how to use the configuration settings:
https://aimeos.org/docs/latest/typo3/customize/
You need the configuration for the backend and the scheduler.
