Is it possible to implement A ticket booking system with Aimeos?
Athulya
Post by Athulya » 04 Jun 2021, 13:30
I have a requirement for a theater seat booking.
1. User needs to choose a seat. each seat has a different rate.
2. Need to show an error message if the seat is already booked.
Is it possible to implement this with Aimeos?
Re: Is it possible to implement A ticket booking system with Aimeos?
Post by aimeos » 05 Jun 2021, 06:21
Yes, that's possible. Use a selection product for the event and variant articles for each seat. Then you can give each variant article a different price and a stock level of "1".
Athulya
Post by Athulya » 07 Jun 2021, 06:01
Thank you. I have done that,
I want to modify the template files, so how can I overwrite the Aimeos shop extension to my website package?
Thanks!
denzen
Post by denzen » 08 Jun 2021, 05:43
You can generate an aimeos extension here:
https://aimeos.org/extensions
Locate this under /typo3conf/ext/aimeos/Private/Extensions/...
I used this for layouting the pdf invoices and e-mails
AIMEOS 21.4.1
FreeBSD
PHP 7.3.8
MySQL 5.7.27
TYPO3 10.4.15
