Determine subpart inside a Price Rule Provider
boettner
Post by boettner » 23 Dec 2021, 08:06
Good morning,
I want to exclude my Price Rule calculations from the mini basket subpart. How can I detect that the current price the Provider is working on comes from the basket and not the catalog?
Best
Robert.
https://aimeos.org/docs/latest/providers/rules/
Re: Determine subpart inside a Price Rule Provider
Post by aimeos » 24 Dec 2021, 07:55
There's no way to handle prices in the basket differently than in the basket as the price rules are applied by the frontend controllers and the mshop code.
The price rules are only applied to the products in the catalog but the ProductPrice plugin uses them es well to stay consistent:
https://github.com/aimeos/aimeos-core/b ... tPrice.php
You can enable the "ignore-modified" setting of the ProductPrice plugin to avoid overwriting product prices which have been changed by other plugins too.
