Can't use existing delivery address
Re: Can't use existing delivery address
Post by aimeos » 28 Nov 2019, 11:37
All outstanding 2019.10 fixes have been tagged now (including aimeos/aimeos-core: 2019.10.6).
Please remove the "x-dev" versions again and test if everything works now (delivery address and saving customer in JQAdm without modified flag if not changed).
MikaelNazarenko
Expert
Post by MikaelNazarenko » 28 Nov 2019, 12:13
isModified method seems working perfect, I checked for customer exactly. But there is problems with delivery address:
1. It always duplicates existing delivery address after checkout. I mean it creates one more the same address.
2. When I select existing address, click next, then click back - no delivery address is selected.
These problems come because of addressid filed, it is not filled in Address fromArray and toArray methods. For now I fixed it for myself by extending Address and filling addressid.
My composer:
   "aimeos/ai-admin-jqadm": "2019.10.x",
        "aimeos/ai-payments": "^2019.07",
        "aimeos/aimeos-core": "2019.10.x",
        "aimeos/aimeos-laravel": "2019.10.x",
My packages verisons:
aimeos/ai-admin-jqadm                 2019.10.6 Aimeos ai-admin-jqadm extension
aimeos/ai-admin-jsonadm               2019.10.2 Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html                 2019.10.9 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi              2019.10.2 Aimeos JSON API extension
aimeos/ai-controller-frontend         2019.10.3 Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs             2019.10.4 Aimeos ai-controller-jobs extension
aimeos/ai-gettext                     2019.10.1 Aimeos Gettext extension
aimeos/ai-laravel                     2019.10.2 Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-payments                    2019.10.1 Payment extension for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer                 2019.10.1 SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core                    2019.10.6 Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel                 2019.10.1 Professional, full-featured and high performance Laravel e-commerce package for online shops and complex B2B projects
Post by aimeos » 28 Nov 2019, 15:13
Thanks, we made "order.base.address.addressid" public in fromArray()/toArray() too now. Also, we've done one change in the HTML client to store that property in a better way.
Can you try again?
composer req aimeos/aimeos-core:2019.10.x-dev aimeos/ai-client-html:2019.10.x-dev
MikaelNazarenko
Expert
Post by MikaelNazarenko » 28 Nov 2019, 15:26
Ok, thanks, I will try!
HTML client: - which files have you changed ? did you change templates ? Because then I need modify my extension
Post by aimeos » 28 Nov 2019, 17:32
No, the checkout address delivery class only.
MikaelNazarenko
Expert
Post by MikaelNazarenko » 28 Nov 2019, 17:37
Yes it works. Only one thing I noticed: if customer doesn't have existing delivery address there two options available like billing and create new, but no one selected by default. As I remember before like billing option was selected in this case by default.
Thank you so much !
Post by aimeos » 28 Nov 2019, 19:02
Initially, "like billing address" is still selected for both, logged in and guest users.
Do you already have data in your session?
MikaelNazarenko
Expert
Post by MikaelNazarenko » 28 Nov 2019, 20:00
Nice! Now seems everything is fine) I hope))
So should I use dev versions ?
"aimeos/ai-client-html": "2019.10.x-dev",
"aimeos/aimeos-core": "2019.10.x-dev",
Post by aimeos » 28 Nov 2019, 20:07
aimeos/aimeos-core has been tagged now (2019.10.7) to fix the problem.
MikaelNazarenko
Expert
Post by MikaelNazarenko » 28 Nov 2019, 20:53
So I can use "aimeos/aimeos-core": "2019.10.7" ?
but what is for "aimeos/ai-client-html": "2019.10.x-dev" ?
