Can't use existing delivery address
MikaelNazarenko
Expert
Post by MikaelNazarenko » 27 Nov 2019, 13:30
Hello!
Versions info:
aimeos/ai-admin-jqadm                 2019.10.x-dev ac5080a Aimeos ai-admin-jqadm extension
aimeos/ai-admin-jsonadm               2019.10.2             Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html                 2019.10.8             Aimeos ai-client-html extension
aimeos/ai-client-jsonapi              2019.10.1             Aimeos JSON API extension
aimeos/ai-controller-frontend         2019.10.3             Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs             2019.10.3             Aimeos ai-controller-jobs extension
aimeos/ai-gettext                     2019.10.1             Aimeos Gettext extension
aimeos/ai-laravel                     2019.10.2             Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-payments                    2019.10.1             Payment extension for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer                 2019.10.1             SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core                    2019.10.x-dev e2194bf Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel                 2019.10.1             Professional, full-featured and high performance Laravel e-commerce package for online shops and complex B2B projects
When I am on checkout proccess I select existing delivery address (another from billing). Then I click next to delivery point. Then I click back to address tab. And here new delivery address is selected.. Also before I selected existing address I have modified some fields of it. And fields were not saved...
I have disabled my extension and all my customization..
I am very worry about this surprise, because it is on live site.. I am not sure 100% that it is a bug, but seems it happened after updates aimeos and I disabled all my customizations...
Please, help to fix it
Screenshots:
https://prnt.sc/q2tjqo
https://prnt.sc/q2tk4t
MikaelNazarenko
Expert
Re: Can't use existing delivery address
Post by MikaelNazarenko » 27 Nov 2019, 14:32
The same bug even here http://laravel.demo.aimeos.org/
When I modify existing delivery address on checkout - changes not saved. And on last step is old data from existing address. Also if I get back to addresses - new address is selected, but I was selecting exiting address...
MikaelNazarenko
Expert
Post by MikaelNazarenko » 27 Nov 2019, 15:27
File
vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Common/Item/Address/Base.php
	 * Sets the item values from the given array and removes that entries from the list
	 * @param array &$list Associative list of item keys and their values
	 * @param boolean True to set private properties too, false for public only
	 * @return \Aimeos\MShop\Common\Item\Address\Iface Address item for chaining method calls
	public function fromArray( array &$list, $private = false )
	    $item = parent::fromArray( $list, $private );
		foreach( $list as $key => $value )
			if( strncmp( 'customer.address.', $key, 17 ) !== 0 ) {
				$key = str_replace( ['order.base.address.', 'customer.'], $this->prefix, $key );
			} else {
				$key = str_replace( 'customer.address.', $this->prefix, $key );
            if(!empty($list['order.base.address.countryid']) && $list['order.base.address.countryid'] == 'LV') {
                dd($key);
The output of dd is:
"customer.address.address.salutation"
I think problem here
MikaelNazarenko
Expert
Post by MikaelNazarenko » 27 Nov 2019, 15:49
https://github.com/aimeos/aimeos-core/b ... e.php#L600
I think it where the problem is. I guess developer have done mistake, because str_replace tries to find first element from array of its first argument and replace it and then second element and so on. Maybe I am wrong, but I have changed that line with:
 $replaced = 0;
                $key = str_replace( ['order.base.address.'], $this->prefix, $key, $replaced );
                if(!$replaced) {
                    $key = str_replace( ['customer.'], $this->prefix, $key );
And it works.
Please fix it well! thank you !
MikaelNazarenko
Expert
Post by MikaelNazarenko » 28 Nov 2019, 07:47
A lot of bugs with delivery address in checkout process!!!! ((((
After I selected existing address - the address is not preselected!
And each time when I select existing address in checkout process - it duplicates and add the same address to user!
I don't understand what happened (
MikaelNazarenko
Expert
Post by MikaelNazarenko » 28 Nov 2019, 09:16
For me problems were because of addressid was missed;
I extended Order\Base Address,
fromArray method:
case 'customer.address.id':
                    $item->setAddressId($value);
                    break;
toArray:
        $list = parent::toArray( true );
        if( $private === true ) {
            $list['order.base.address.addressid'] = $this->getAddressId();
        return $list;
Post by aimeos » 28 Nov 2019, 09:59
This should have been fixed since last week but we didn't tag the fixes yet (now: aimeos/ai-client-html 2019.10.9). Can you please update your installation and see if everything works for you now?
MikaelNazarenko
Expert
Post by MikaelNazarenko » 28 Nov 2019, 10:56
Please, sorry for my stressed posts ) I was stressed and I had small time to fix it ) Thank you a lot for support! I hope maybe I am also helpful sometimes.
This is my current composer:
        "aimeos/ai-admin-jqadm": "2019.10.x-dev",
        "aimeos/ai-payments": "^2019.07",
        "aimeos/aimeos-core": "2019.10.x-dev",
        "aimeos/aimeos-laravel": "2019.10.x",
Please tell what I should set to composer to get right versions? I will check it
Post by aimeos » 28 Nov 2019, 11:01
Just run "composer update". Then, you should get "aimeos/ai-client-html: 2019.10.9".
MikaelNazarenko
Expert
Post by MikaelNazarenko » 28 Nov 2019, 11:04
Should I leave dev for core and ai-admin-jqadm ? Or have you added fixes to normal verison ? For me important fixes for isModified() method )
