To Add a new field to order ,below the invoice number
Re: To Add a new field to order ,below the invoice number
Post by aimeos » 09 Aug 2024, 13:49
Seems like after your change it fails to send the "refid" to the server correctly.
hyalcin
Post by hyalcin » 28 Aug 2024, 11:47
I applied the above steps for the additions I made to the mshop_order_address table.
default/shema/order.php
<?php
return [
    'table' => [
        'mshop_order_address' => function (\Aimeos\Upscheme\Schema\Table $table) {
            $table->string('care_fund');
            $table->string('insurance_number');
            $table->integer('care_level');
I don't have a problem displaying these fields in the address form. However, I couldn't understand how to edit the order/item.php in the last section.
$context = app('aimeos.context')->get(true);
        $controller = new \Aimeos\Controller\Frontend\Basket\Standard($context);
        $include = ['basket/address', 'basket/product'];
        $basket = $controller->get()->setCustomerId($context->user());
        $basketData = json_decode(json_encode($basket), true);
        Log::debug('created basket: ' . json_encode($basketData));
How can I access the fields I have newly added in the address?
Post by aimeos » 29 Aug 2024, 10:27
You need to add a decorator to the customer address manager for the new fields in the customer address table:
https://aimeos.org/docs/latest/models/e ... /#easy-way
