display products of all shops in one catalog
olevacho
Post by olevacho » 21 Oct 2020, 16:49
Hey,
I added second shop into marketplace using this tutorial https://aimeos.org/docs/Laravel/Configu ... iple_shops
Before adding second shop catalog with products was accessed at this url http://myshop3.cov/shop
After setup i have :
1)default shop can be accessed http://myshop3.cov/default/shop
2)second shop can be accessed http://myshop3.cov/supershop1/shop
3)both urls http://myshop3.cov/shop and http://myshop3.cov/ return Not Found 404
Is there way to display products from both shops at one url like before? http://myshop3.cov/shop
When i remove lines:
'jsonapi' => ['prefix' => '{site}/jsonapi', 'middleware' => ['web', 'api']],
'account' => ['prefix' => '{site}/profile', 'middleware' => ['web', 'auth']],
'default' => ['prefix' => '{site}/shop', 'middleware' => ['web']]
from config/shop.php then i can only see products from default shop. But this is not i want. I need to display products from all shops on one catalog page.
Thanks in advance
P.S. Laravel version - 6.18.42 , Php - 7.2.31 , Ubuntu 16
Re: display products of all shops in one catalog
Post by aimeos » 22 Oct 2020, 08:11
Using the Aimeos multi-vendor feature creates separate shops that doesn't share any data.
If you want to build a market place (which is the feature you are requesting), you need the market place extension from the Aimeos company: https://aimeos.org/laravel-marketplace-ecommerce
olevacho
Post by olevacho » 24 Oct 2020, 22:43
thanx.
I see there are also https://aimeos.com/gigacommerce/ . Does it include marketplace features too?
What are key differences between https://aimeos.org/laravel-marketplace-ecommerce and https://aimeos.com/gigacommerce/ ?
Post by aimeos » 25 Oct 2020, 08:24
The market place extension allows you to build market places or complex B2B systems while the #gigacommerce extension enables you to scale your shop or market place to more articles than Amazon offers.
olevacho
Post by olevacho » 25 Oct 2020, 23:32
Does it mean that if i need marketplace i should buy marketplace extension. But if i need powerful marketplace with 1 billion products i need to buy both marketplace+gigacommerce extensions?
If yes than how many products are supported by marketplace extension?
Post by aimeos » 26 Oct 2020, 06:40
Yes, in this case you need both. Without the #gigacommerce extension, a MySQL database will scale to 100k products easily but will then become slow when full text search and e.g. sorting by price is combined.
olevacho
Post by olevacho » 29 Oct 2020, 21:13
what hardware configuration do i need for 100K products (only for marketplace)?
what hardware configuration do i need for 1000 000 000 products ( for marketplace + #gigacommerce)?
Post by aimeos » 31 Oct 2020, 09:40
For 100k products, a standard virtual server is enough. It depends on the number of page impressions per second how much power you need.
For 1 billion items, there's an article in our blog regarding performance tests including a description of the hardware used:
https://aimeos.org/tips/gigacommerce-ai ... ion-items/
olevacho
Post by olevacho » 31 Oct 2020, 22:42
Thank You for article. But hardware characteristic is bit confusing.
LAMP VM: 8 Core, 16GB RAM, 17GB on SSD
ElasticSearch VM: 8 Core, 32GB RAM, 465GB on SSD
Does it mean that you used two virtual machines: one for web server and one for ElasticSearch. Do i need also two VMs to make it working ?
Post by aimeos » 01 Nov 2020, 08:18
For the demo setup, two virtual servers have been used but you can also start with one. It just needs enough RAM for ElasticSearch.
