Dynamic Script and Css
AmzoooJibal
Post by AmzoooJibal » 18 Mar 2021, 16:05
when i look to the ext packages templates all is'nt a laravel blade templae, so for that there is any way to dynamically load the script and the css for each page ? for exmple in resources/view/vendor/shop/aimeos/index.blade.php i need to work with section or yield then in ext package change the section or yield dynamically .
Re: Dynamic Script and Css
Post by aimeos » 19 Mar 2021, 06:34
You can add scripts and CSS URLs in the header-standard.php files of the components, e.g. for the detail component:
https://github.com/aimeos/ai-client-htm ... andard.php
They will be added automatically to the pages.
AmzoooJibal
Post by AmzoooJibal » 19 Mar 2021, 14:11
this is for the client side what about admin side ?
Post by aimeos » 20 Mar 2021, 14:13
Yes, this is for the client side. For the admin backend, add your code to the files in the ./themes/ directory. Read https://aimeos.org/docs/latest/admin/jq ... stom-cssjs for more details.
