How do I integrate Razorpay Payment Gateway
veeran ambalam
Post by veeran ambalam » 02 Jul 2021, 20:04
I Tried with insenseanalytics/omnipay-razorpay but I think this is outdated, can you help me with any other better way to integrate. Can I find Razorpay Provider anywhere Or should I write my custom Payment Provider.
Re: How do I integrate Razorpay Payment Gateway
Post by aimeos » 04 Jul 2021, 05:52
There seems to be an "official" Omnipay driver but it also seems to be outdated:
https://github.com/razorpay/omnipay-razorpay
The best option is to create a PR for updating the driver and if the maintainer doesn't merge it, fork the driver.
veeran ambalam
Post by veeran ambalam » 05 Jul 2021, 19:23
Instead of ai-payments, Can I create controllers for Payment Gateway and update the status of the order? What would be the difference between creating controllers on Laravel and ai-payments?
mhbhat
Post by mhbhat » 20 Jan 2023, 08:03
@veeran ambalam did you find a solution how to integrate razorpay?
VirtualSpy
Post by VirtualSpy » 04 Feb 2023, 03:37
mhbhat wrote: 20 Jan 2023, 08:03 @veeran ambalam did you find a solution how to integrate razorpay?
Just follow the create payment provider documentation https://aimeos.org/docs/latest/provider ... e/payment/ and try to integrate there razorpay payment gateway api. If you get success to integrate razorpay payment gateway api https://razorpay.com/docs/payments/serv ... ntegration in payment provider of Aimeos please reply here otherwise you can integrate razorpay create link api https://razorpay.com/docs/api/payments/ ... ment-link there , it is more easy than integrate razorpay payment gateway api for payment and order status only.
