Laravel theme extension
AmzoooJibal
Post by AmzoooJibal » 24 Sep 2021, 16:59
i have generated a new laravel extension here:
https://aimeos.org/extensions#:~:text=C ... %20classes.
Then i put it in the ext directory ? but the extension style not loaded there is some other things i need to setup ?
regards,
Re: Laravel theme extension
Post by aimeos » 26 Sep 2021, 10:21
The CSS/JS files must be published to ./public/vendor/... using:
php artisan vendor:publish --tag=public --force
Usually that is done automatically when you execute "composer up" and you have been following the installation guide:
https://github.com/aimeos/aimeos-larave ... of-content
AmzoooJibal
Post by AmzoooJibal » 27 Sep 2021, 09:29
thank you so much i think it's like in the old version we need just to put it in the ext package
Thank you
