Error running composer update with fresh install of Laravel
davidlanier
Post by davidlanier » 21 Jul 2015, 13:39
I created a fresh install of Laravel 5.1.4, then modified the .env file and the composer.json file per the instructions at https://aimeos.org/docs/Laravel/Install_Aimeos, then ran composer update and received the following error:
> cp -r ext/*/client/extjs/deploy/* public/packages/aimeos/shop/client/extjs/deploy/
cp: cannot stat ‘ext/*/client/extjs/deploy/*’: No such file or directory
Script cp -r ext/*/client/extjs/deploy/* public/packages/aimeos/shop/client/extjs/deploy/ handling the post-update-cmd event returned with an error
  [RuntimeException]
  Error Output: cp: cannot stat ‘ext/*/client/extjs/deploy/*’: No such file or directory
I am the owner of the directories with full rwx permissions.
Should I continue with the Artisan commands?
Re: Error running composer update with fresh install of Lara
Post by aimeos » 21 Jul 2015, 16:47
Sorry, that "copy" line in the composer.json file doesn't work if no extensions are installed and I thought we removed this from the docs again (done now). Delete this line and try again, then it will work.
davidlanier
Post by davidlanier » 21 Jul 2015, 17:20
Removing that line corrected the error, but I noticed that the syntax of the app.php providers array seems to have changed from what you are showing in your documentation.
You have:
    return array(
        'providers' => array(
            'Aimeos\Shop\ShopServiceProvider',
However the syntax in 5.1.4 now is:
 App\Providers\AppServiceProvider::class,
        App\Providers\EventServiceProvider::class,
        App\Providers\RouteServiceProvider::class,
	 Aimeos\Shop\ShopServiceProvider::class,
Anyway, now when running
I get the following error:
 [MW_DB_Exception]
  Executing statement "
                        SELECT DISTINCT lvu."id", lvu."name" as "label", lvu."name" as "code",
                                lvu."company", lvu."vatid", lvu."salutation", lvu."title",
                                lvu."firstname", lvu."lastname", lvu."address1",
                                lvu."address2", lvu."address3", lvu."postal", lvu."city",
                                lvu."state", lvu."countryid", lvu."langid",
                                lvu."telephone", lvu."email", lvu."telefax", lvu."website",
                                lvu."birthday", lvu."status", lvu."vdate", lvu."password",
                                lvu."created_at" AS "ctime", lvu."updated_at" AS "mtime", lvu."editor"
                        FROM "users" AS lvu
                        WHERE ( lvu."name" LIKE 'demo-%' )
                        LIMIT 100 OFFSET 0
                " failed: SQLSTATE[42S22]: Column not found: 1054 Unknown column 'lvu.company' in 'field list'
Post by aimeos » 21 Jul 2015, 17:53
davidlanier wrote:Removing that line corrected the error, but I noticed that the syntax of the app.php providers array seems to have changed from what you are showing in your documentation.
That's essentially the same, just another way to get the class name.
davidlanier wrote: Anyway, now when running
 [MW_DB_Exception]
Someone else reported that problem before. Due to an unknown reason
            "php artisan vendor:publish",
            "php artisan migrate",
haven't been executed on "composer update". The first one should publish the database migration file to "./database/migrations" while the second one should execute the migrations so the missing fields are added. Can you check if both lines are in the "post-install-cmd" and "post-update-cmd" section of your composer.json file? They should be the first entries and the order is important too! Then run "composer update" and see if the Aimeos migration file is in "./database/migrations" and if the user table gets updated. If not, are the commands executed by composer at all?
davidlanier
Post by davidlanier » 21 Jul 2015, 18:15
I wasn't paying attention and just noticed that I have two publish directives in the post update section:
 "post-install-cmd": [
            "php artisan clear-compiled",
            "php artisan optimize"
        "pre-update-cmd": [
        "post-update-cmd": [
            "php artisan vendor:publish --tag=public --force",
Post by aimeos » 21 Jul 2015, 18:43
davidlanier wrote:I wasn't paying attention and just noticed that I have two publish directives in the post update section:
That's necessary because otherwise, the CSS and JS file won't get updated with new versions.
Does it work now if you execute "composer update" and afterwards "artisan aimeos:setup"?
davidlanier
Post by davidlanier » 21 Jul 2015, 19:00
Yes it is working now. There were some additional files pulled down in the composer update so all is well with the world now.
Thanks for you help! :D
Post by aimeos » 21 Jul 2015, 19:09
davidlanier wrote:No. I'm still getting the unknown column lvu.company in the select statement.
Can you execute the following commands by hand:
php artisan migrate
Then, the user table should get updated. Check if
"./database/migrations/2015_03_06_000000_aimeos_users_table.php" is there and the migrations are executed.
davidlanier
Post by davidlanier » 21 Jul 2015, 19:12
Sorry, I forgot to run the update first and you replied before I had a chance to edit my previous reply.
All is well now, except I'm getting a blank page when opening in my browser. I should have the demo right? I think I still need to make the csrf edits though.
Post by aimeos » 21 Jul 2015, 19:24
davidlanier wrote: All is well now, except I'm getting a blank page when opening in my browser. I should have the demo right? I think I still need to make the csrf edits though.
Please continue with the setup. You need to add a base template, then you can test:
https://aimeos.org/docs/Laravel/Adapt_base_template
https://aimeos.org/docs/Laravel/Test_installation
The CSRF thing is necessary if you are using version 1.0.x to get through the checkout.
