How can I add links to the pages that I created using CMS in the header section?
I want to add links in the header section of the pages that I created in CMS. Can someone help me the process do I have to create a new component for that or is there already built in solution for it?
laravel version: 9.2
Aimeos version: 2022.07.2
php version: 8.0
env: win 10.
php version: 8.0
env: win 10.
- VirtualSpy
- Advanced
Re: How can I add links to the pages that I created using CMS in the header section?
According to me you should create your theme and use this theme then you will get packages\your theme\views\base.blade.php from there you can add links in header
https://aimeos.org/docs/latest/laravel/themes/
Yes I have tried that. But I wanted to create something which will allow me to show the enabled links from CMS to header. that way I don't have to change the code everytime I add or remove a page.VirtualSpy wrote: ↑17 Aug 2022, 08:02 According to me you should create your theme and use this theme then you will get packages\your theme\views\base.blade.php from there you can add links in header
