Google Apple pay Implementation
Wall0fDeath
Post by Wall0fDeath » 31 Aug 2022, 06:44
Good morning!
I got a task, to make the apple and googlepay work with Aimeos. But I don't really know, how to start this whole process.
I got some information about that, they should work with Stripe, so basically i have to get the user's card data from the google or apple account and send it somehow to the Stripe.
I already set a working Stripe sandbox in my Aimeos, but I don't know, how and where should I start to write this to be nice and acceptable.
Can I use the existing Stripe omnipay provider, or should I make a new extension/provider to call Omnipay's Stripe with the new data source?
Can I get a little help, or would you be so kind to show me the "nice way" of this?
Have a nice day :)
VirtualSpy
Re: Google Apple pay Implementation
Post by VirtualSpy » 31 Aug 2022, 07:07
Wall0fDeath wrote: 31 Aug 2022, 06:44 Good morning!
Have a nice day :)
you should create payment provider https://aimeos.org/docs/latest/provider ... e/payment/
Post by aimeos » 31 Aug 2022, 07:31
If Stripe supports Apple and Google Pay, use the Aimeos Stripe integration if possible.
Do both require any special handling in Stripe?
Wall0fDeath
Post by Wall0fDeath » 28 Oct 2022, 08:54
Thank you for the answers.
It seems like Stripe in Ai-payments works with the Omnipay backend what is require card data.
So I have 2 options :
- make a frontend with google / apple pay integration, get card data and send it through stripe.
- make a provider, what uses Stripe Checkout as a redirect, and on that page customers can chose between card, transfer, google, apple pay, link, wallet etc payments. As I saw it, this can be made with a simple provider, so this is what I will try to make.
- ( or +1 ... fork and rework ai-payments stripe to actually use that 'onsite' variable - what currently does nothing - and redirect to checkout if it is false. )
Post by aimeos » 28 Oct 2022, 08:59
Wall0fDeath wrote: 28 Oct 2022, 08:54 - ( or +1 ... fork and rework ai-payments stripe to actually use that 'onsite' variable - what currently does nothing - and redirect to checkout if it is false. )
If you go that route, we are happy to integrate your changes if you create a pull request :-)
