listing categories
mahammadareef
listing categories
Post by mahammadareef » 24 Nov 2022, 13:09
I want to list out 20 categories on the home page (in the shop by category section) - based on the option value given in categories - how to achieve this -explain to me with steps
and what is the exact use of option + value options available in the catalog adding part
Re: listing categories
Post by aimeos » 25 Nov 2022, 14:30
The option/value pairs are just configuration values which can be stored in each category and which can be used e.g. in the template to enable the CSS based megamenu. But you can't filter for those values as they are stored as JSON encoded string in the "config" column of the mshop_catalog table.
If you you explicitly want to filter the categories in the database by a custom value, you could add a manager decorator adding a new column to the mshop_catalog table:
https://aimeos.org/docs/latest/models/extend-managers/
mahammadareef
Post by mahammadareef » 30 Nov 2022, 12:01
okay assume i added one coloumn is_branded_category , how to write filter option , if posssible please show it in this data() function of my component (here it retrives all the category tree )
  public function data( \Aimeos\Base\View\Iface $view, array &$tags = [], string &$expire = null ) : \Aimeos\Base\View\Iface
        $tree = \Aimeos\Controller\Frontend::create( $this->context(), 'catalog' )->uses( $this->domains() )
			->getTree( \Aimeos\Controller\Frontend\Catalog\Iface::LIST );
		$products = \Aimeos\Controller\Frontend::create( $this->context(), 'product' )->uses( $this->domains() )
			->category( $tree->getChildren()->getId()->all(), 'promotion' )->search();
		$this->addMetaItemCatalog( $tree, $expire, $tags );
		$this->addMetaItems( $products, $expire, $tags, ['product'] );
		$view->homeTree = $tree;
		// $view->homeStockUrl = $this->stockUrl( $products );
		return parent::data( $view, $tags, $expire );
Post by aimeos » 01 Dec 2022, 15:07
The catalog controller has a compare() method where you can add custom conditions:
https://github.com/aimeos/ai-controller ... hp#L26-L35
In your example:
$cntl = \Aimeos\Controller\Frontend::create( $this->context(), 'catalog' );
$categories = $cntl->compare( '==', 'is_branded_category', 1 )->slice( 0, 20 )->search();
