Discount rule by supplier
AleksandarJovanovic
Post by AleksandarJovanovic » 06 Jan 2023, 20:05
laravel version 9.36.4 , Aimeos version 2022.10.3 and PHP version 8.1.3
Hello, can i set discount rule by suppliers or other atribute. I just see discount by category and that works great.
Best regard
Alex
Re: Discount rule by supplier
Post by aimeos » 08 Jan 2023, 09:46
Sure, you can :-)
Create a new catalog rule decorator checking for suppliers attached to products similar to the category rule decorator:
- https://github.com/aimeos/aimeos-core/b ... tegory.php
- https://aimeos.org/docs/latest/providers/rules/
Make sure, you add "supplier" to the fetched product domains so the supplier items are attached to the products in your rule decorator, e.g. in:
https://aimeos.org/docs/2022.x/config/c ... e/#domains
Search for "configuration client/html/catalog domains" in the docs.
