modifyng mshop_product table with new coloumn
mahammadareef
Post by mahammadareef » 01 Feb 2023, 07:23
want to customize the mshop_product table and add a new column called identifier ...
and want to store a unique identifier when the product gets created ...how i can do this .. explain to me in steps
condition: add after code column
Re: modifyng mshop_product table with new coloumn
Post by aimeos » 02 Feb 2023, 13:32
The product code is exactly tailored for that.
If you want to add a new column nevertheless, implement a decorator for the manager:
https://aimeos.org/docs/latest/models/extend-managers/
mahammadareef
Post by mahammadareef » 03 Feb 2023, 15:45
Thank you for help .....
extending manager is okay but I want to know...
how to add an identifier (column) after code (column) in mshop_product ( table )
Post by aimeos » 05 Feb 2023, 16:26
The used Upscheme library supports modifiers but no after() because only MySQL is offering that and column order isn't important.
The list of available column modifiers offered by Upscheme:
https://upscheme.org/#column-modifiers
mahammadareef
Post by mahammadareef » 06 Feb 2023, 05:24
can we alter the mshop_product table by using laravel default migrations ?
Post by aimeos » 07 Feb 2023, 08:17
Yes, you can but it may create confusion where the additional column is created.
