Bulk text translation with DeepL?
columbo
Post by columbo » 26 Oct 2023, 09:16
with "AI-based text translation" DeepL translation of single text elemets is possible.
found here https://aimeos.org/tips/aimeos-2019-10-lts-release/ and https://aimeos.org/docs/2023.x/config/a ... #translate
Is there also an option to translate multipe text elements at once / as batch?
eg. translation of all product names (about 3.000 text items) from DE to EN at once.
Thank you
Re: Bulk text translation with DeepL?
Post by aimeos » 27 Oct 2023, 17:42
No that's not possible out of the box and you have to write your own script to do that.
columbo
Post by columbo » 07 Dec 2023, 14:51
What would be the best way to create a script for the mass translation of product texts?
Load the relevant texts from the DB table (SQL) -> call DeepL-API -> write translation to the DB?
Which table should be considered?
Is there another method or function of Aimeos that can be used?
Thank you!
Post by aimeos » 10 Dec 2023, 10:54
Use the Aimeos text manager to iterate e.g. over all English texts, call the DeepL API and save the returned text as new text item:
https://aimeos.org/docs/latest/models/s ... fficiently
columbo
Post by columbo » 18 Dec 2023, 07:53
I'm trying to translate all product texts with type = 'name' from DE to EN and ES via DeepL API.
Selecting the 'name' texts and calling the API works
$productManager = \Aimeos\MShop::create( $this->context(), 'product' );
$filter = $productManager->filter();
$cursor = $productManager->cursor( $filter );
while( $items = $productManager->iterate( $cursor, ['text'] ) ) {
    foreach ($items->getRefItems('text', 'name') as $textitems) {
            foreach( $textitems as $entry ){
                $text_source = $entry['text.content'];
                echo($text_source);
    * get translation, call Deepl API
    $deepLy = new DeepLy(env('DEEPL_API_KEY'));
    $text_translated_de = $deepLy->translate($text_source, 'DE');
    $text_translated_es = $deepLy->translate($text_source, 'ES');
    * update product db entry, add transaltion to
    $items = $productManager->create();
    $items->addListItem( 'text', 'name', $text_translated_de,  );
    $items = $productManager->save( $items );
but two questions remain:
1) How can I check if an EN or ES translation already exists?
-> Only product name texts without an EN OR ES translation should be selected
2) How can I add the translated text to the product item?
I checked https://aimeos.org/docs/latest/models/m ... reate-item , but couldn't get it to work
Thank you
Post by aimeos » 22 Dec 2023, 09:14
columbo wrote: 18 Dec 2023, 07:53
    $partitions = $productItem->getRefItems( 'text', 'name', 'default' )->partition( function( $item ) {
        return $item->getLanguageId() === 'DE' ? 'DE' : 'tx';
    if( !$partitions->has( 'tx' ) ) {
        $textItem = $partitions->get( 'DE' )->first();
        // translate and add translation
See PHP Map documentation: https://php-map.org/
columbo wrote: 18 Dec 2023, 07:53 2) How can I add the translated text to the product item?
https://aimeos.org/docs/latest/models/m ... ated-items
    $listItem = $productManager->createListItem();
    $textItem = $textManager->create()->setType( 'name' )->setLanguageId( 'en' )->setContent( $text_translated_en );
    $productItem->addListItem( 'text', $listItem, $textItem->setLabel( 'Text in EN' );
    $productManager->save( $productItems );
