PostgreSQL: product search with multiple terms
columbo
Re: PostgreSQL: product search with multiple terms
Post by columbo » 09 Jan 2021, 09:17
tried it once again; results are not ranked by phrase queries
A product that exactly matches the search term is listed somewhere in between of the result product list
How can I retrieve the search query? Set log/manager/standard/loglevel to 7, but could not find the query .
Post by aimeos » 09 Jan 2021, 09:51
Did you set your configuration correctly in your ./config/shop.php?
'madmin' => [
	'log' => [
		'manager' => [
			'standard' => [
				'loglevel' => 7
columbo
Post by columbo » 09 Jan 2021, 11:50
The config.php setting was correct, but could not finde a PgSQL protocol entry before, saved config.php file again and now its listed - anyway, here the logged PgSQL query: (term1 = "paprika"; term2 = "rot")
Class: Aimeos\MShop\Index\Manager\PgSQL
SELECT mpro."id" , MIN(mpro."code") AS "s0", MIN(ts_rank(to_tsvector(mindte."content"), to_tsquery( 'paprika:* | rot:* | "paprika <-> rot"' ))) AS "s1"
    FROM "mshop_product" AS mpro
    LEFT JOIN "mshop_index_catalog" AS mindca ON mindca."prodid" = mpro."id"
    LEFT JOIN "mshop_index_text" AS mindte ON mindte."prodid" = mpro."id"
    WHERE ( ( mpro."siteid" = '1.' OR mpro."siteid" = '' ) AND ( mindca."catid" IS NOT NULL AND ( mpro."status" = 1 AND ( mpro."type" = 'event' OR mpro."start" IS NULL OR mpro."start" <= '2021-01-09 12:42:00' ) AND ( mpro."end" IS NULL OR mpro."end" >= '2021-01-09 12:42:00' ) ) AND ( mindte."siteid" = '1.' OR mindte."siteid" = '' ) AND mindte."langid" = 'de' AND CAST( to_tsvector(mindte."content") @@ to_tsquery( 'paprika:* | rot:* | "paprika <-> rot"' ) AS integer ) > 0 ) )
    GROUP BY mpro."id"
    ORDER BY "s0" ASC, "s1" DESC
    OFFSET 0 ROWS FETCH NEXT 48 ROWS ONLY
Post by aimeos » 09 Jan 2021, 12:31
You sort by product code first, so the ranking doesn't have any effect:
columbo
Post by columbo » 09 Jan 2021, 13:38
ohh, yes indeed :oops:
we are using client/html/catalog/lists/sort => 'code'
is it possible to list products by code in category lists (without any search terms)
but to list by relevance (and not by product code) when search term(s) is/are used?
Post by aimeos » 11 Jan 2021, 08:48
If you create you own controller/action with the catalog/tree and add the setting in that method to the configuration, then it will be only used by that page.
