[Solved] Display product name(s) of an order id
Re: Display product name(s) of an order id
Post by aimeos » 19 Jan 2021, 10:56
What else do you want to know?
rowild
Post by rowild » 20 Jan 2021, 09:51
Well, first, i would like to know where
$orders
comes from?
Because that throws an error: "Call to a member function keys() on null"
:-) Thank you!
Post by aimeos » 20 Jan 2021, 10:19
Sorry, this was a left-over from the first try where the decorator called the method of the inner object. It's removed now in the example.
rowild
Post by rowild » 20 Jan 2021, 16:55
Excellent - thank you!
Next step: How to access products...
rowild
Post by rowild » 20 Jan 2021, 17:22
Aha, this seems to do it:
$curr = $orderItem->getBaseItem()->getProducts();
foreach( $curr as $prodId => $product ) {
	echo '<pre>';
	var_export( $prodId . ': ' . $product->get( 'order.base.product.name' ) );
	echo '</pre>';
die();
Am I on the right track?
Re: [Solved] Display product name(s) of an order id
Post by aimeos » 21 Jan 2021, 17:05
Yes. Instead of the "magic" get() method, you should use e.g. getName() to retrieve the product name because the item methods will return default values instead of NULL like get() does. For the list of available methods, have a look at the interface:
https://github.com/aimeos/aimeos-core/b ... /Iface.php
