[Solved] Display product name(s) of an order id
rowild
Hi!
On the account history page (account/history/list-body-standard.php), I would like to display the products' names that were purchased, next or below to the order id.
How can I do that?
Thank you!
How can I do that?
Thank you!
Re: Display product name(s) of an order id
The order details are currently only loaded in the detail subpart:
https://github.com/aimeos/ai-client-htm ... #L222-L229
You have to write a decorator for the account history component that loads the details of all orders after the list subpart added them to the view:
https://github.com/aimeos/ai-client-htm ... d.php#L218
Here's the documentation how to implement client html decorators:
https://aimeos.org/docs/latest/frontend ... omponents/
rowild
I create a class "Productdetailsinorderhistory" in <path>/src/Client/Html/Common/Decorator/Productdetailsinorderhistory.php:
The Typoscript looks like this:
However, I get this error:
I do not see the "incompatibility" - what am I doing wrong?
In VSCode, I have Intelephense installed, which tells me this about the error:
Method 'Aimeos\Client\Html\Common\Decorator\Productdetailsinorderhistory::addData()' is not compatible with method 'Aimeos\Client\Html\Common\Decorator\Base::addData()'.
Undefined type 'Aimeos\Client\Html\Common\Decorator\Aimeos\MW\View\Iface'.
Expected type 'Aimeos\Client\Html\Common\Decorator\Aimeos\MW\View\Iface'. Found 'void'.
<?php
namespace Aimeos\Client\Html\Common\Decorator;
class Productdetailsinorderhistory
extends \Aimeos\Client\Html\Common\Decorator\Base
implements \Aimeos\Client\Html\Common\Decorator\Iface
public function addData(
\Aimeos\MW\View\Iface $view,
array &$tags = [],
string &$expire = null): Aimeos\MW\View\Iface
$view = parent::addData($view, $tags, $expire);
return $view;
public function process()
// do something before
$this->getClient()->process();
// do something afterwards
plugin.tx_aimeos.settings {
client.html {
account {
history.order.decorators.global {
0 = Productdetailsinorderhistory
Fatal error: Declaration of Aimeos\Client\Html\Common\Decorator\Productdetailsinorderhistory::addData(Aimeos\MW\View\Iface $view, array &$tags = Array, ?string &$expire = NULL): Aimeos\Client\Html\Common\Decorator\Aimeos\MW\View\Iface must be compatible with Aimeos\Client\Html\Common\Decorator\Base::addData(Aimeos\MW\View\Iface $view, array &$tags = Array, ?string &$expire = NULL): Aimeos\MW\View\Iface in /var/www/html/packages/theme/Resources/Private/Extensions/aimeos/client/html/src/Client/Html/Common/Decorator/Productdetailsinorderhistory.php on line 15
There was a backslash missing in the method signature (return value declaration) of addData():
not
This is fixed now in the docs.
public function addData( \Aimeos\MW\View\Iface $view, array &$tags = [], string &$expire = null) : \Aimeos\MW\View\IfaceCode: Select all
public function addData( \Aimeos\MW\View\Iface $view, array &$tags = [], string &$expire = null) : Aimeos\MW\View\IfaceProfessional support and custom implementation are available at Aimeos.com
rowild
How do I properly assign the reuqired info in the foreach-loop so that I can read it in the "summary/detail..." partial in
"account/history/list-body-standard template"?
My current try with tempArrays seems to very wrong (I get a product displayed, but it is always only one product, and it is always the same, which has no relation at all to any of the orders).
I also cannot find what the "load()" function does in
"\Aimeos\Controller\Frontend::create( $context, 'basket' )->load( $orderItem->getBaseId() );
(Found nothing in the docu.)
Also, it is not possible to var_dump or var_export $basket or $view->summaryBasket (timeout because of self reference). How can I check what is put in that variable? Which methods are available on summaryBasket?
<?php
* Display details about ordered products in the customer order history.
* Decorates Account/History/List/Standard
// namespace Aimeos\Client\Html\Account\History\Order\Decorator;
//Show details about products in the order history in customer account.
public function addData( \Aimeos\MW\View\Iface $view, array &$tags = [], string &$expire = null ): \Aimeos\MW\View\Iface
if ( $allOrders = $view->get('listsOrderItems', map() ) !== null)
// Already added data (=> Account/History/Lists/Standard.php)
$allOrders = $view->get('listsOrderItems', map());
$tempOrderItem = [];
$tempBasket = [];
foreach ( $allOrders as $orderItem ) {
$basket = \Aimeos\Controller\Frontend::create( $context, 'basket' )->load( $orderItem->getBaseId() );
array_push($tempOrderItem, $orderItem);
array_push($tempBasket, $basket);
$view->orderItem = $orderItem;
$view->summaryBasket = $basket;
return $view;
The most efficient way is:
Make sure you only add the decorator to the account/history/list subpart.
$cntl = \Aimeos\Controller\Frontend::create( $this->getContext(), 'order' );
$view->listsOrderItems = $cntl->uses( ['order/base', 'order/base/product'] )
->sort( '-order.id' )->search();
return $view;
rowild
Thank you for the solution!
But - this is not easy at all. I do not understand why I have to create an `order` context now, when I try to get products? Also: what is `order/base` and order/base/product?
IMO there should be examples in the docu that explain various scenarios...
You want to fetch orders, not the basket. "order/base" and "order/base/product" are the related items that should be fetched too.rowild wrote: 17 Jan 2021, 15:05 But - this is not easy at all. I do not understand why I have to create an `order` context now, when I try to get products? Also: what is `order/base` and order/base/product?
Help is always welcome!rowild wrote: 17 Jan 2021, 15:05 IMO there should be examples in the docu that explain various scenarios...
rowild
Help can only be given, when the person, who writes it, understands the topic.
If you help me understand, I am more than willing to write.
