Error of showing Home category at admin part
Re: Error of showing Home category at admin part
Post by aimeos » 15 Oct 2022, 13:45
Check your browser console for errors.
MilaWeb
Post by MilaWeb » 16 Oct 2022, 11:24
Here is console with errors. I checked these files - they are present at resources folder. Also clear cache after build and it's not help
MilaWeb
Post by MilaWeb » 18 Oct 2022, 11:46
MilaWeb wrote: 16 Oct 2022, 11:24 Here is console with errors. I checked these files - they are present at resources folder. Also clear cache after build and it's not help
Problem fix - remove hot file from public folder and then run npm run build
