Error of showing Home category at admin part
Laravel version 9.31.0, Aimeos version 2022.07, PHP version 8.0.23, Ubuntu 20.04.5 LTS
At production instance categories page admin 'Home' category doesn't show as usual.
While click at it - error "Item with ID "undefined" in "catalog.id" not found"
And at json massive at structure got 0 element (while at local version no 0 element and everything is normal).
- category_2.jpg (186 KiB) Viewed 8613 times
Re: Error of showing Home category at admin part
Is there any JS error in the browser console before or after the error?
Does an upgrade to the new 2022.10 LTS fixes the issue?
No any js error at console.
While now try to upgrade version there was this about github token and can't to finish upgrade (attch login error after try upgrade)
- upgrade.jpg (149.02 KiB) Viewed 8603 times
- login.jpg (87.58 KiB) Viewed 8604 times
- console.jpg (86.87 KiB) Viewed 8604 times
You have to run "php artisan aimeos:shop" to upgrade the table structure
Try to run "php artisan aimeos:shop" but no this command
- ahop_command.jpg (22.66 KiB) Viewed 8601 times
Sorry, it must be:
php artisan aimeos:setupProfessional support and custom implementation are available at Aimeos.com
Thank you, run
command work without error - but now login page not work 404
php artisan aimeos:setup- Attachments
- login_2.jpg (23.93 KiB) Viewed 8596 times
- VirtualSpy
- Advanced
runMilaWeb wrote: 13 Oct 2022, 18:26 Thank you, runcommand work without error - but now login page not work 404Code: Select all
php artisan config:clearCode: Select all
php artisan route:clearRe: Error of showing Home category at admin part
Add "p" as prefix to the CMS page routes like here:MilaWeb wrote: 13 Oct 2022, 18:26 Thank you, runcommand work without error - but now login page not work 404Code: Select all
https://github.com/aimeos/aimeos/blob/m ... op.php#L40
Got it, links are ready - but styles for login page not work. "npm run build" doesn't help
- login.jpg (26.3 KiB) Viewed 8458 times
