Code Required error when registering
sica-d
Re: Code Required error when registering
Post by sica-d » 19 Dec 2022, 10:11
aimeos wrote: 19 Dec 2022, 09:39 Only if you enabled SHOP_MULTISHOP too. If you don't want a multi-vendor setup with merchant registration, disable SHOP_MULTISHOP and SHOP_REGISTRATION. Then, /register will be available too but only for customers.
I do want a multi-vendor setup with shop registration enabled. Everything works fine as you described, but the issue remains the code field that is required, as stated on your previous post. Sorry if this is back and forth, but it seems to resolve my issue, there must be a shop ID or number field on the registration field, and it is just not there. And thanks again for your patience
Post by aimeos » 19 Dec 2022, 10:22
Sorry, we've seen that the register.blade.php file in the current Aimeos distribution was missing the code for the account. This has been fixed now, please add this to your ./resources/views/auth/register.blade.php file:
https://github.com/aimeos/aimeos/blob/m ... php#L9-L23
sica-d
Post by sica-d » 19 Dec 2022, 12:33
aimeos wrote: 19 Dec 2022, 10:22 Sorry, we've seen that the register.blade.php file in the current Aimeos distribution was missing the code for the account. This has been fixed now, please add this to your ./resources/views/auth/register.blade.php file:
Thank you very much.
I see I have a new error: "Missing required parameter for [Route: verification.verify] [URI: {site}/verify-email/{id}/{hash}] [Missing parameter: site]."
But I will battle with this one on my own for a while. Thanks again
Post by aimeos » 19 Dec 2022, 13:27
Do you have a stack trace?
sica-d
Post by sica-d » 19 Dec 2022, 13:38
aimeos wrote: 19 Dec 2022, 13:27 Do you have a stack trace?
app /Providers/AppServiceProvider.php: 50
return URL::temporarySignedRoute('verification.verify', $time, $params);
Is this what you are referring to?
Post by aimeos » 19 Dec 2022, 13:53
Yes. These additional lines should fix the problem:
https://github.com/aimeos/aimeos/commit ... b0914ccb3f
Can you please check?
sica-d
Post by sica-d » 19 Dec 2022, 14:05
aimeos wrote: 19 Dec 2022, 13:53 Yes. These additional lines should fix the problem:
Hi - Thank you
Class "App\Providers\Request" not found
app/Providers/AppServiceProvider.php : 53
$params['site'] = Request::route( 'site', Request::input( 'site', config( 'shop.mshop.locale.site', 'default' ) ) );
Post by aimeos » 19 Dec 2022, 14:15
sica-d
Post by sica-d » 19 Dec 2022, 14:24
aimeos wrote: 19 Dec 2022, 14:15 Added this line: https://github.com/aimeos/aimeos/commit ... 4882178ec6
Is it better now?
Non-static method Illuminate\Http\Request::route() cannot be called statically
Post by aimeos » 19 Dec 2022, 14:34
Maybe it must be:
use Illuminate\Support\Facades\Request;
