Code Required error when registering
onensensy
Post by onensensy » 14 Dec 2022, 15:23
Hey, I'm experiencing an error when registering Users.
The error says:
Whoops! Something went wrong.
The code field is required.
Screenshot from 2022-12-14 18-20-34.png (68.03 KiB) Viewed 2577646 times
Laravel 9, PHP: 8.1.12, Linux Ubuntu
sica-d
Re: Code Required error when registering
Post by sica-d » 15 Dec 2022, 09:04
Any answer on this? Stuck here for days
VirtualSpy
Post by VirtualSpy » 15 Dec 2022, 09:28
sica-d wrote: 15 Dec 2022, 09:04 Any answer on this? Stuck here for days
check your .env there is shop registration is enable else something is wrong in RegisteredUserController class
sica-d
Post by sica-d » 15 Dec 2022, 10:40
Thank you for you reply, however I have no clue where or what to look for?
Sorry, have to learn sometime :D
Post by aimeos » 15 Dec 2022, 18:05
When you enable SHOP_REGISTRATION, user registration is for merchants, is used along with SHOP_MULTISHOP and requires an unique code for the new shop site that will be created. If you only want to offer upfront registration for customers, don't enable SHOP_REGISTRATION.
Also, user accounts for customers will be automatically created at the end of the checkout process so upfront registration is only necessary if only logged in customers should be able to order.
onensensy
Post by onensensy » 16 Dec 2022, 17:32
How do i Supply the code?
sica-d
Post by sica-d » 19 Dec 2022, 05:19
aimeos wrote: 15 Dec 2022, 18:05 When you enable SHOP_REGISTRATION, user registration is for merchants, is used along with SHOP_MULTISHOP and requires an unique code for the new shop site that will be created. If you only want to offer upfront registration for customers, don't enable SHOP_REGISTRATION.
Thanks again, but that part I fully understand. I just do not know how to enable the registration process to generate the unique shop code for merchants?
Post by aimeos » 19 Dec 2022, 09:22
If you enable SHOP_REGISTRATION, registering merchants can enter a custom code of their own. There will be a field displayed in the registration form and checked for uniqueness.
sica-d
Post by sica-d » 19 Dec 2022, 09:37
aimeos wrote: 19 Dec 2022, 09:22 If you enable SHOP_REGISTRATION, registering merchants can enter a custom code of their own. There will be a field displayed in the registration form and checked for uniqueness.
Thanks again, finally I am getting on. There is no other field displayed as per the screenshot above, even with Shop_Registration enabled?
Post by aimeos » 19 Dec 2022, 09:39
Only if you enabled SHOP_MULTISHOP too. If you don't want a multi-vendor setup with merchant registration, disable SHOP_MULTISHOP and SHOP_REGISTRATION. Then, /register will be available too but only for customers.
