Aimeos Context Serialization Issue
sergey030
Re: Aimeos Context Serialization Issue
Post by sergey030 » 08 Jan 2025, 11:51
Hey, guys!
The problem turned out to be not in getDepositeOrder(), but in the event registration for plugins.
The problem is that in the listeners object there are closures here is an example of the object. How can I remove it from here ?
I have attached screenshots where there are closures in the listeners property.
public function register(\Aimeos\MW\Observer\Publisher\Iface $p): \Aimeos\MW\Observer\Listener\Iface
    $p->attach($this->object(), 'addProduct.after');
    $p->attach($this->object(), 'deleteProduct.after');
    return $this;
Снимок экрана 2025-01-08 в 13.50.28.png (38.58 KiB) Viewed 40458 times
Снимок экрана 2025-01-08 в 13.49.01.png (90.61 KiB) Viewed 40458 times
Post by aimeos » 11 Jan 2025, 15:40
Use this to remove all listeners:
$orderItem->off()
