Aimeos Context Serialization Issue
MuhammadSohailAfzal
Post by MuhammadSohailAfzal » 27 Jul 2023, 21:25
Hi everyone,
I am trying to create a new queue job as laravel provided.
and the function I want to process by this job is using aimeos context object.
now whenever I tried to dispatched the job it throws and exception related to serialization of aimeos context class
ErrorException: serialize(): Aimeos\MShop\Context::__sleep() should return an array only containing the names of instance-variables to serialize in file D:\laragon\www\kitchen-aid\vendor\laravel\framework\src\Illuminate\Queue\Queue.php on line 158
PHP Version: 8.1
Aimeos Version: 2023.07
Laravel Version: 10
I am attaching my some code might be it can help to understand the issue
ProductService
class ProductService
    protected $productRepository;
    private $aimeosContext;
    public function __construct(ERPProductRepository $productRepository)
        $this->productRepository = $productRepository;
        $this->aimeosContext = app('aimeos.context')->get(true);
    public function syncMshopProductFromErpProduct(array $product)
        /* @var AimeosItem $productItem */
        /* @var AimeosManager $productManager */
        /* @var AimeosItem[] $productItems */
        $productManager = MShop::create($this->aimeosContext, 'product');
Queue Job
class ProcessErpProducts implements ShouldQueue
    use Dispatchable, InteractsWithQueue, Queueable, SerializesModels;
    private ProductService $productService;
     * Create a new job instance.
    public function __construct(ProductService $productService)
        $this->productService = $productService;
     * Execute the job.
    public function handle(): void
        $product = []; //product data
        $this->productService->syncMshopProductFromErpProduct($product);
Dispatching the Job
ProcessErpProducts::dispatch($this->productService);
Re: Aimeos Context Serialization Issue
Post by aimeos » 29 Jul 2023, 10:57
Strange, the __sleep() method of the context object already does that:
https://github.com/aimeos/aimeos-core/b ... t.php#L102
Can you add debug output in that line to see what get_object_vars() returns?
sergey030
Post by sergey030 » 12 Dec 2024, 12:41
Hi guys!
I have the same issues when i try to add product in basket i have a message.
#message: "serialize(): Aimeos\MShop\Context::__sleep() should return an array only containing the names of instance-variables to serialize"
This data when debug the in __sleep method get_object_vars( $this )
Can you suggest how this can be fixed ?
Aimeos version 2023.10
MacOS, PHP 8.2, Laravel Framework 9.52.5
Снимок экрана 2024-12-12 в 14.40.35.png (201.12 KiB) Viewed 146026 times
Post by aimeos » 12 Dec 2024, 12:56
Thank you for the debug output!
We've changed the __sleep() methods and return only the keys now. Can you please install these versions and try again?
composer req aimeos/aimeos-base:2023.10.x-dev aimeos/aimeos-core:2023.10.x-dev
sergey030
Post by sergey030 » 12 Dec 2024, 13:39
Yeah, the error's gone, but there's a new one.
{ "message": "Declaration of Aimeos\\Base\\Filesystem\\Manager\\Laravel::__sleep() must be compatible with Aimeos\\Base\\Filesystem\\Manager\\Standard::__sleep(): array", "exception": "Symfony\\Component\\ErrorHandler\\Error\\FatalError", "file": "/var/www/html/vendor/aimeos/ai-laravel/src/Base/Filesystem/Manager/Laravel.php", "line": 57, "trace": [] }
I think we still need to adapt this method to the current __sleep implementation( see in attachements ).
Снимок экрана 2024-12-12 в 15.38.19.png (79.05 KiB) Viewed 146019 times
Post by aimeos » 12 Dec 2024, 13:43
Sorry, forgot that one. Please update using:
composer req aimeos/ai-laravel:2023.10.x-dev
sergey030
Post by sergey030 » 12 Dec 2024, 14:01
Sorry guys another error appeared with the serialization of the closure. Can you take a look, please ?
Exception {#2674 // vendor/aimeos/ai-client-jsonapi/src/Client/JsonApi/Base.php:205
  #message: "Serialization of 'Closure' is not allowed"
  #code: 0
  #file: "/var/www/html/vendor/aimeos/aimeos-core/src/MShop/Order/Manager/Basket/Standard.php"
  #line: 198
  trace: {
    /var/www/html/vendor/aimeos/aimeos-core/src/MShop/Order/Manager/Basket/Standard.php:198 {
      Aimeos\MShop\Order\Manager\Basket\Standard->saveItem(Iface $item, bool $fetch = true): Iface …
      ›         $serialized = base64_encode(serialize($clonedItem));
      › \t\t$idx = 1;
      arguments: {
        $value: Aimeos\MShop\Order\Item\AimeosOrder {#2947 …}
    /var/www/html/vendor/aimeos/aimeos-core/src/MShop/Common/Manager/Base.php:210 {
      Aimeos\MShop\Common\Manager\Base->save($items, bool $fetch = true) …
      › if( method_exists( $this, 'saveItem' ) ) {
      › \t$this->saveItem( $item, $fetch );
      › } else {
      arguments: {
        $item: Aimeos\MShop\Order\Item\Basket\Standard {#2781 …}
        $fetch: true
Снимок экрана 2024-12-12 в 15.59.39.png (234.61 KiB) Viewed 145998 times
Post by aimeos » 12 Dec 2024, 14:14
Can you post your code so we can see what you are trying to serialize?
sergey030
Post by sergey030 » 12 Dec 2024, 14:19
Yes, please.
$serialized = base64_encode( serialize( clone $item->getItem() ) );
Снимок экрана 2024-12-12 в 16.17.04.png (253.57 KiB) Viewed 145979 times
Post by aimeos » 12 Dec 2024, 16:37
The getDepositOrder() is your problem. You can't serialize a basket which contains a using a manager. Instead, you have to extend the order manager and add the data when fetching the records from the database. Overwrite/extend the searchRefs() method for that: https://github.com/aimeos/aimeos-core/b ... d.php#L432
