Moritz
Post by Moritz » 23 Sep 2022, 06:49
The siteid of both tables was NULL.
I set both to an empty string and now all users are displayed.
Are these changes become part of the upgrade wizard or do I still execute them manually?
UPDATE fe_users_address SET mtime = '0001-01-01 00:00:00' WHERE mtime = 0;
UPDATE fe_users_address SET ctime = '0001-01-01 00:00:00' WHERE ctime = 0;
UPDATE fe_users SET siteid = '' WHERE siteid IS NULL;
UPDATE fe_users_address SET siteid = '' WHERE siteid IS NULL;
And the change of this line https://github.com/aimeos/ai-typo3/blob ... o3.php#L49 to
if( !$db->hasTable( 'mshop_locale_site' ) || !$db->hasColumn( 'mshop_locale_site', 'siteid' ) )
PHP 8.2.24
Typo3 v12.4.23 LTS
Aimeos web shop 24.10.2
Post by aimeos » 24 Sep 2022, 06:14
Moritz wrote: 23 Sep 2022, 06:49 Are these changes become part of the upgrade wizard or do I still execute them manually?
Can you investigate where the mtime/ctime values in your fe_users_address come from?
Guess, they are not inserted by Aimeos because otherwise, these columns wouldn't have "0" values.
Moritz wrote: 23 Sep 2022, 06:49 UPDATE fe_users SET siteid = '' WHERE siteid IS NULL;
This should be already done because of this line:
https://github.com/aimeos/ai-typo3/blob ... o3.php#L60
Moritz wrote: 23 Sep 2022, 06:49 UPDATE fe_users_address SET siteid = '' WHERE siteid IS NULL;[/code]
These lines have been added now to set the site ID values of the fe_users_address table correctly:
https://github.com/aimeos/ai-typo3/blob ... hp#L63-L65
Moritz wrote: 23 Sep 2022, 06:49 And the change of this line https://github.com/aimeos/ai-typo3/blob ... o3.php#L49 to
This should not be necessary if you upgrade from scratch.
Moritz
Post by Moritz » 26 Sep 2022, 08:13
I think I can't...
The values was already there before the update.
Ah perfect.
In my v22.7.3-pre6 the tablename bugfix isn't fixed.
You can evaluate this better.
But is the logic correct?
You skip the migration task if mshop_locale_site has the column siteid?
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 26 Sep 2022, 08:45
Moritz wrote: 26 Sep 2022, 08:13
There's still a dependency error. Currently, the TYPO3 siteid migration task runs after the general siteid migration task and thus, the column is already created and the TYPO3 task won't do anything. We've changed the dependency so the TYPO3 siteid migration task will be executed before the general siteid migration task. Then, it should be correct.
Here's a new package:
https://aimeos.org/fileadmin/download/a ... 3-pre7.zip
Moritz
Post by Moritz » 11 Oct 2022, 13:16
Thank you for the prerelease!
I found another issue when I want to download a file from order.
There is a foreign key on fe_users_list.type to fe_users_list_type.id of datatype integer.
The SQL tries to insert a string in this column.
The exception occurs in "aimeos/Resources/Libraries/aimeos/ai-client-html/src/Client/Html/Account/Download/Standard.php(243)".
Maybe there is a missing migration of the foreign key?
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 12 Oct 2022, 11:21
The setup task for migrating the type columns in the fe_users_* tables had been removed by accident in 2022.04. Now, it's available again in the 22.10.1-pre1 pre-release. Please test if the typeid column in fe_users_list and fe_users_property is changed from INT to VARCHAR:
https://aimeos.org/fileadmin/download/a ... 1-pre1.zip
Moritz
Post by Moritz » 12 Oct 2022, 12:16
When installing v22.10.1-pre1 with my old v18.10.11 tables I get the following exception.
With v22.7.3-pre7 the upgrade wizard is successfully.
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 12 Oct 2022, 12:24
MySQL doesn't accept quotes in table and column names by default. Here's a new package:
https://aimeos.org/fileadmin/download/a ... 1-pre2.zip
Moritz
Post by Moritz » 12 Oct 2022, 12:55
The installation of v22.10.1-pre2 works now.
But there are some users missing again in the backend.
Also the entries in fe_users_address are away of these users.
Because of that I can't see any orders of those users in frontend account history.
In v22.7.3-pre7 that was working.
PHP 8.2.24
Typo3 v12.4.23 LTS
Moritz
Post by Moritz » 12 Oct 2022, 13:19
The catalog tree to filter with by category isn't working too...
Edit: Or do you have changed the strukture of the template again?
I modified the styles to display the filter tree like a sidemenu.
Works also in v22.7.3-pre7 but not with v22.10.1-pre2.
PHP 8.2.24
Typo3 v12.4.23 LTS
