Post by aimeos » 12 Oct 2022, 15:08
Moritz wrote: 12 Oct 2022, 12:55 But there are some users missing again in the backend.
Also the entries in fe_users_address are away of these users.
Do they have a site ID of "" (empty string) or NULL again?
Did you upgrade from your 18.10 database structure or from an already upgraded one?
Moritz
Post by Moritz » 13 Oct 2022, 06:48
Sorry it was my fault.
I didn't upgrade from my 18.10 database structure.
Now the users are in the list.
But I saw no order in frontend for my user.
In the template file of the order history no orders are found for this user.
PHP 8.2.24
Typo3 v12.4.23 LTS
Aimeos web shop 24.10.2
Moritz
Post by Moritz » 13 Oct 2022, 08:33
And how is it about the catalog filter tree?
I see you have made some modifications there "aimeos_22.10.1-pre2\Resources\Libraries\aimeos\ai-client-html\templates\client\html\catalog\filter\tree-partial.php".
The basis of my style changes was on v22.7.3-pre7.
Now the tree isn't display correct anymore.
Are these modifications also done in the next official version and does more modifications on templates planed?
I don't want to change my styles every version 🙂
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 13 Oct 2022, 09:37
Did you check if fe_users.uid is the same as mshop_order_base.customerid?
Moritz
Post by Moritz » 13 Oct 2022, 10:19
Yes.
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 13 Oct 2022, 10:31
Is the site ID different?
Moritz
Post by Moritz » 13 Oct 2022, 10:32
The site ID of users and orders are the same.
Or do you mean another one?
PHP 8.2.24
Typo3 v12.4.23 LTS
Moritz
Post by Moritz » 13 Oct 2022, 13:27
I've downgrade to v22.7.3-pre7 and execute the upgrade wizard on my old database structure from v18.10.11.
In this case the user can see his order history.
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 13 Oct 2022, 13:32
Can you please enable debug logging of the executed SQL statements to check why that happens?
Moritz
Post by Moritz » 13 Oct 2022, 14:42
The problem is that I do not know the reason why the orders are not displayed.
Due to this ignorance, I also don't know where to investigate.
I can provide you with the results of the upgrade wizard. Debug logging should be enabled there.
DB was v18.10.11 and Aimeos v22.10.1-pre2.
SQLs_upgrade_wizard.zip
(12.41 KiB) Downloaded 1588 times
And here a question from some posts before
Have you an explanation why die category filter are not always expanded anymore?
Before experimenting with v22.10.1-pre2 the full filter tree was shown...
PHP 8.2.24
Typo3 v12.4.23 LTS
