Solr Integration
sramey
Solr Integration
Post by sramey » 19 May 2017, 21:13
Haven't seen anything about using Solr in place of MySQL for catalog search. Figured there would a seemless way to do this. Any help is much appreciated!
Re: Solr Integration
Post by aimeos » 20 May 2017, 12:27
For a Solr integration, you can replace the classes in the Aimeos index domain with ones that store the data as documents in Solr:
https://github.com/aimeos/aimeos-core/t ... ex/Manager
