AIMEOS PACKAGE IN CUSTOM DIRECTORY INSTEAD OF VENDORS
sammiewai
Post by sammiewai » 22 May 2017, 16:57
I would like to install aimeos in a custom directory rather than in the vendors while using the composer.
How should I go about it?
Am using Laravel 5.2, aimeos ~2016.10 on Linux environment.
Thanks.
Re: AIMEOS PACKAGE IN CUSTOM DIRECTORY INSTEAD OF VENDORS
Post by aimeos » 22 May 2017, 17:32
You can change the directory composer is using in your composer.json but separating the Laravel packages from the rest of the packages in ./vendor/ only works with custom installers. The package type used by Aimeos is "laravel-bundle".
For more details please refer to https://getcomposer.org/doc/articles/cu ... tallers.md
